Forum Topic - "Spawn error" when using pdebug upon serial to debug programs: (24 Items)
I am trying to connect my IDE 6.3.2 under windows to my target board through pdebug upon serial port. Steps below:
1) First try a target of desktop PC with Nutrino installed. It's successful.
2) Second, build an OS image on the desktop PC using the attached build file, then write the image file to floppy disk.
Commands follow:
     mkifs -v debug.build debug.ifs
     dinit -f debug.ifs /dev/fd0
3) Reboot the desktop through the floppy disk, it boots up successfully without error.
4) Try to connect to the desktop target again, the error messages are:
MsgNak received - resending
Remote exhausted 3 retries.
mi_cmd_stack_list_frames: No stack.
info tidlist
Undefined info command: "tidlist".  Try "help info".
set remotebaud 57600
upload C:/QNX632/prac-workspace/Hello/x86/o-g/Hello_gxx11520.tmp /tmp/Hello_g
set qnxremotecwd /tmp
Warning: /cygdrive/c/QNX632/prac-workspace/Hello/C: No such file or directory.
Warning: /QNX632/prac-workspace/Hello/.settings: No such file or directory.
Warning: /QNX632/prac-workspace/Hello/x86: No such file or directory.
Warning: /QNX632/prac-workspace/Hello/x86/o-g: No such file or directory.
Remote (spawn error): Exec format error.
5) I cheked the directory "\tmp" on the target, there is only an empty file (size 0) "Hello_g".
6) Anything missing when building the OS image?
Weiming
Attachment: Text debug.build 854 bytes
Re: "Spawn error" when using pdebug upon serial to debug programs
Is pdebug in /usr/bin/pdebug on the target?
In step 4 "Try to connect to the desktop" - how you are trying to
connect? Do you use launch configuration?
successful.
file, then write the image file to floppy disk. Commands follow:
without error.
> info tidlist
/tmp/Hello_g
directory.
directory.
directory.
directory.
> Thanks
> Weiming
> http://community.qnx.com/sf/go/post8447
AW: "Spawn error" when using pdebug upon serial to debug programs
sorry I didn't mention that I do not use the IDE to launch the binary.
I do that directly on the target, having the env set.
>Von: Laskavaia, Elena
>Gesendet: Dienstag, 27. Mai 2008 15:18
>An: general-ide
>Betreff: Re: "Spawn error" when using pdebug upon serial to
>debug programs
>to connect? Do you use launch configuration?
>successful.
>> build
>> successfully
>without error.
>messages are:
>> info tidlist
>/tmp/Hello_g
>directory.
>directory.
>directory.
>directory.
>or directory.
>only an empty
>> Thanks
>> Weiming
>> General
>General
>http://community.qnx.com/sf/go/post8457
Geschaeftsfuehrung:  Dr. Wolfgang Ptacek  -  Michael Mauser  -  Regis Baudot
Sitz der Gesellschaft: Karlsbad - Registergericht: Mannheim HRB 361395
. Das unerlaubte Kopieren sowie die unbefugte...
pdebug is in "/proc/boot", and the path is set, so that it can be accessed.
On IDE side, I start up through "Run/Debug...", then choose way of pdebug. See the attached picture.
Weiming
Attachment: Image snapshot.JPG 71.97 KB
There are problems with cygwin paths. Can you try new debugger gdb 6.7
u8 from foundry?
accessed.
> Weiming
> http://community.qnx.com/sf/go/post8496
I have the same problems witn IDE 4.6 on Windows XP with serial connection to the target AR91SAM9160-EK with QNX6.4
Image based on BSP AT91SAM9260.
The serial communication between Host and Target work properly.
On Target I start
pdebug /dev/ser2,115200
In IDE when I try to debug in Pdebug configuration next errors occure:
Remote target is little-endian
Remote was unable to open '/dos/kkt_server_g': Input/output error
No registers.
info tidlist
set remotebaud 115200
upload C:/ide-4.6-workspace/GMN/kkt_server/arm/o-le-g/kkt_server_gxx51599.tmp /dos/kkt_server_g
set qnxremotecwd /dos
No symbol "qnxremotecwd" in current context.
Timed out.
Remote (spawn error): Permission denied.
Please show the solution.
RE: "Spawn error" when using pdebug upon serial to debug programs
Can you launch it from default folder (i.e. /tmp)
Looks like remote cwd is failing maybe this cause it not to launch?
From: Leonid Khait [mailto:community-noreply@qnx.com]
Sent: April 17, 2010 1:03 PM
To: general-ide
Subject: Re: "Spawn error" when using pdebug upon serial to debug
programs
connection to the target AR91SAM9160-EK with QNX6.4 Image based on BSP
AT91SAM9260.
On Target I start
Remote was unable to open '/dos/kkt_server_g': Input/output error MsgNak
received - resending No registers.
info tidlist
upload
/dos/kkt_server_g set qnxremotecwd /dos No symbol "qnxremotecwd" in
current context.
Timed out.
General
http://community.qnx.com/sf/go/post51977
Re: RE: "Spawn error" when using pdebug upon serial to debug programs
I try  launch from /tmp ( as default ) before too.
In BSP project /tmp is soft linked to /dev/shmem. And the same problems occure.
The /dos folder I found by mount to Flash Umass strorage drive.
Any time IDE  upload  program to /tmp ( or /dos ) folder with 0 byte lengs.
I tray to debug throug serial line  by pdebug method and  by pppd and qconn too and same problems ( upload file length
is 0 ).
One thing - the serial line speed was 115200. Is it so importent?
Any ideas?
 Thank you.
Is there space left on your device? If it cannot upload binary it
definitely explain problems with debugging.
 is 0 ).
> Any ideas?
>  Thank you.
> http://community.qnx.com/sf/go/post52041
It was definitely enough amount of space in /tmp or /dos folder.
>If it cannot upload binary it definitely explain problems with debugging.
Are there some other ( not enough  space ) conditios  for succsess upload process?
Any envirorment variables, libs, .so files in QNX image, etc. ?
This is really weird that file is created but not written.
Can you create a file locally? I.e. using "cat" or something like that?
> http://community.qnx.com/sf/go/post52044
> Sent: April 19, 2010 12:03 PM
> To: general-ide
> debug programs
> with debugging.
/dev/shmem should always allow to write into the file, unless there is
no free RAM in the system.
On the target, what happens if you do
echo short file > /tmp/foo
Does that create a zero sized file, or an 11 byte file?  If it is a zero
sized file, what is the return value?  You can find this by running
"echo $?" after the command to create the file.
Also, what version of pdebug are you using?  You can check by starting
with -v:
pdebug -v /dev/ser2,115200
Sorry my timeout, I was on a distance from the board.
Yes, /dev/shmem allow to create and write fiiles, the length of file foo after
#echo short file > /tmp/foo is about 11:
# ls -l /tmp
lrwxrwxrwx  1 0         0                10 Apr 23  2010 /tmp -> /dev/shmem
Process 569356 (ls) exited status=0.
# cp /proc/boot/tcpdump /tmp
# ls -l /tmp/tcpdump
-rwxrwxrwx  2 0         0            702941 May 20  2009 /tmp/tcpdump
>with -v:
QNX AT91SAM9260-ek target console:
# pdebug -v /dev/ser2,115200
Process 557068 (pdebug) exited status=0.
This version of pdebug was built on May 20 2009.
ProtoVer 0.3
# Com port /dev/ser2 initialized ok.
Target initialized ok.
pdebug initialized
Host resent message with id 9 (0x9). Resending response.
Host resent message with id 4 (0x4). Resending response.
Host resent message with id 5 (0x5). Resending response.
Host resent message with id 7 (0x7). Resending response.
TargetLoad argc=0 envc=0 envv=
cmdline=
stdio=|| || ||
Beg TextToHost 5 /dev/ptyp0
End TextToHost 0 (No error)
Spawn of /tmp/hello_g failed: 8 (Exec format error)
Host resent message with id 8 (0x8). Resending response.
Same time IDE Debug view console:
Remote was unable to open '/tmp/hello_g': Input/output error
No registers.
info tidlist
upload C:/ide-4.6-workspace/GMN/hello/arm/o-le-g/hello_g /tmp/hello_g
Timed out.
So I'm continue on the truble with pdebug from IDE through serial line.
Please help.
P.S. In that system Debuggin through Ethernet and qconn work without problem,
but I need only through serial line.
And you saying after you attempt to launch debugger and it fails, you check /tmp/hello_g  its size is 0?
Yes!
This is ARM AT91SAM9260-ek controller with according BSP.
Sorry, this is full issue:
# ls -l /tmp
# ls tmp
hello_g
Process 577548 (ls) exited status=0.
# ls /tmp/hello_g
/tmp/hello_g
Process 585740 (ls) exited status=0.
# ls -l /tmp/hello_g
-rwxrwxrwx  3 0         0                 0 Jan 01 00:14 /tmp/hello_g
Process 593932 (ls) exited status=0.
Process 602124 (cp) exited status=0.
Process 610316 (ls) exited status=0.
Btw with this serial baud rate can you get it working as console? Maybe
it is wrong rate?
> # ls -l /tmp
> # ls tmp
> hello_g
> # ls /tmp/hello_g
> /tmp/hello_g
> http://community.qnx.com/sf/go/post52513
I can workin on console without any problems on 115200.
Sorry, I'll try and report on 57600 on sanday.
On serial speed 57600 I have the same problems.
Can you try lower rates?
> http://community.qnx.com/sf/go/post52655
The issues I've seen in the past with pdebug all relate to a baud rate set too high, or mismatched between the host and
the target.
When you tried the lower baud rate, did you change it in the IDE AND in the launch of pdebug? (http://www.qnx.com/
developers/docs/6.3.0SP3/neutrino/utilities/p/pdebug.html)
The pdebug use message also states that pdebug should not be launched with a baud rate higher than 57600:
>use pdebug
<snip>
  /device_name[,baud]   Open and use the specified device, such as
                        /dev/ser1, optionally setting the baud rate.
                      **baud rates higher than 57600 NOT recommended**
<snip>
> > General
Please get me more info about cygwin configuration in Windows XP.
On my PC  I found some older ( before QNX IDE installation )
cygwinccompiler.pyc program in C:\IBMTOOLS\Python22\Lib\distutils folder and
also some descriptions in Windows registryr:
HCEY_LOCAL_MACHINE
 -SOFTWARE
    -Cygnus Solutions
        -Cygwin
          -Mounts V2
            /                                     c:\cygwin
            /usr/bin                          c:\cygwin/bin
            /usr/lib                            c:\cygwin/lib
Some time ago I  create c:\cygwin directory for IDE properly work.
So have I create now c:\cygwin\bin and  c:\cygwin\lib  folders too
or
I need to clean all cygwin key descriptions from Windows HKEY_LOCAL_MACHINE and HKEY_LOCAL_USER registry?
At me the problem proceeds.
Has tested the same Host PC with IDE for communications with PC x86 with QNX Momentics through COM-port. Debugging both
through pdebug, and through PPP connection - qconn work normally.
As soon as I am switched HOST on AT91SAM9260-ek + BSP with same  COM-port communication tools debugging both through
pdebug, and through PPP-qconn does not work.
Thero length debuging program file in /tmp->/dev/shmem problem occures.
And same time debugging through Ethernet-qconn works normally.
P.S.
On Host - PC with IDE I use Prolific USB-> COM the adapter.
Please show me  the path on pdebug sources for problem of "pdebug serial" studying.
