Forum Topic - Disassembly view: (6 Items)
Disassembly view
I'm debugging a dump file. I open the disassembly view, click on the up arrow key to see code above what is currently in
 the windows, but I can't.  I can press the down arrow, which expands the view from the bottom, but that's it. I tried
to force the address but nothing happens.
The word "Pending..." flashes real fast in the disassembly view.
Didn't see anything related in the log file.
Re: Disassembly view
Try to enable gdb verbose console (option in Debug tab of launch
configuration) and check gdb console while running it.
Maybe gdb does not return disassembly for address above (which can
happened if it does not belong to any function).
> up arrow key to see code above what is currently in the windows, but I
> bottom, but that's it. I tried to force the address but nothing happens.
> http://community.qnx.com/sf/go/post7984
I updated to gdb 6 us on the Windows and QNX box.  From the Command line on QNX everything works ok.  On Windows it has
gotten worst.
This what the gdb console shows:
391-data-disassemble -f S:/br10_4_0/visions/pretraitement/lissebrd.c -l 1845 -n 100 -- 1
92-data-disassemble -s 0x80775ba -e 0x807761e -- 0
393-data-evaluate-expression inxStart
But the dissassemble view now shows Target request failed: Target is not responding ( timed out).  This was working with
 gdb that came with 6.3.2 ( 5.? )
I updated to version 6 u8
> > General
has gotten worst.
Could you try with gdb update 8? http://community.qnx.com/sf/frs/do/viewRelease/projects.toolchain/frs.gdb.gdb_6_7_u8
Also increase gdb mi timeout. Getting dissasembly from gdb is very slow
operation.
Go to Windows->Preferences->C/C++0>Debug->GDB MI and enter 10000 as
debugger timeout
> line on QNX everything works ok.  On Windows it has gotten worst.
> -l 1845 -n 100 -- 1
> not responding ( timed out).  This was working with gdb that came with
> 6.3.2 ( 5.? )
> but I
> happens.
> > > General
> http://community.qnx.com/sf/go/post7989
> operation.
> debugger timeout
Already set at 10000 and I already had upgrade to the lastest gdb.  All the files were on a remote disk except the core
file was local.  I tried moving the project on the local disk, but something got lost.
At anyrate I tried with different corefile/executable and all is fine.  May something is wrong with the core file i'm
using.  I'll keep an eye on this.
> > -l 1845 -n 100 -- 1
> > 6.3.2 ( 5.? )
> > but I
> > happens.
> > > > General
> > General
