Hi, I am using Qnx Ide.In this the terminal window is showing as not connected.How to enable it. Thanks Regards V.Murugadoss
Which version of IDE you are running? murugadoss v wrote: > > Hi, > I am using Qnx Ide.In this the terminal window is showing as not > connected.How to enable it. > Thanks > > Regards > V.Murugadoss > > _______________________________________________ > General > http://community.qnx.com/sf/go/post7970 >
hi, I am using ide 6.3.2 version. Thanks & regards V.murugadoss
So it is IDE 4.0.1. In this case see small triangle at the terminal view local toolbar. Click on it and set appropriate values for the communication parameters. murugadoss v wrote: > > hi, > I am using ide 6.3.2 version. > > Thanks & regards > V.murugadoss > > > > _______________________________________________ > General > http://community.qnx.com/sf/go/post8020 >
