Forum Topic - App Profiler 2 - error in libprofiling version 1.1: (6 Items)
I tried to switch to the latest libprofiling version 1.1 but i get a linker error.
./libprofiling.so: undefined reference to `__ldd_register_eh'
Any hint how to fix this?
TIA
/hp
Re: App Profiler 2 - error in libprofiling version 1.1
Why it is error from .so? You should link to it statically
(libprofilingS.a)...
(Error is because libc is old and does not have this method)
> linker error.
> TIA
> /hp
> http://community.qnx.com/sf/go/post7768
AW: App Profiler 2 - error in libprofiling version 1.1
so which libc is required?
I run it with a 6.3.2
is the libc the reason for why I should use the static shared libS.a?
or has the libS.a to be used all the time?
with the version 1.0 I could use the "normal" .so and link dynamically.
>Von: Laskavaia, Elena
>Gesendet: Dienstag, 6. Mai 2008 21:58
>An: general-ide
>Betreff: Re: App Profiler 2 - error in libprofiling version 1.1
>> linker error.
>> TIA
>> /hp
>> General
>General
>http://community.qnx.com/sf/go/post7769
Geschaeftsfuehrung:  Dr. Wolfgang Ptacek  -  Michael Mauser  -  Regis Baudot
Sitz der Gesellschaft: Karlsbad - Registergericht: Mannheim HRB 361395
Re: AW: App Profiler 2 - error in libprofiling version 1.1
Linking statically reduces performance overhead (by couple of jumps at
each function call).
I don't understand what is the problem with unresolved symbols, this
code did not change...
You can continue to use 1.0 if it works better for you, until we fix
this problem (which will happened soon because I am working on this
library right now)
It is still 6.3.2 libc which is required by it should have
`__ldd_register_eh' defined...
AW: AW: App Profiler 2 - error in libprofiling version 1.1
I will double check my env and come back to you later
>Gesendet: Mittwoch, 7. Mai 2008 15:47
>An: general-ide
>Betreff: Re: AW: App Profiler 2 - error in libprofiling version 1.1
>jumps at each function call).
>symbols, this code did not change...
>we fix this problem (which will happened soon because I am
>working on this library right now)
>dynamically.
>General
>http://community.qnx.com/sf/go/post7799
Re: AW: AW: App Profiler 2 - error in libprofiling version 1.1
I did a double check.
And what to say ... MEA CULPA
due to the problems caused by the multiple use of the eclipse configuration folder (like with the ptrace import problem)
 - I was using a bad compilation environment.
This is now working.
I guess the -configuration option would be worth to mention a bit stronger
thanks
hp
