Forum Topic - QNX postmortem debugging is broken in IDE 5.0.1: (3 Items)
Whenever I try to do postmortem debugging using a core file, the following error message would appear in a "Problem
Occurred" popup window:
Error while launching command: gdb --version
Any idea what is wrong here? Thanks.
Re: QNX postmortem debugging is broken in IDE 5.0.1
You need to use the QNX postmortem launch configuration as opposed to the C/C++ one.
Thank you David for pointing it out. Coming from IDE 4.7.0, I didn't notice there is a new QNX postmortem launcher
option. That was the issue.
Best regards,
Vincent
