Forum Topic - Qnx Ethernet problem: (2 Items)
I am using PandaBoard ES.I download qnx-sdp-6.6 bsp and put MLO,U-boot and ifs-omap4430-panda.bin to sd card.And I put
to Pandaboard and everything works fine.But If I compile Bsp and I use "ifs-omap4430-panda.bin" form images folder,
pandaboard ethernet isn't work.I get following error end of booting:
ksh: No controlling tty (open /dev/tty: No such device or address)
ksh: warning: won't have full job control
And I run ifconfig command on PandaBoard,command output is:
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
What can I solve this problem?
Thank for your interest.
Re: Qnx Ethernet problem
And other problem(in my opinio it is main problem) is :
Starting onboard network driver, generating unique MAC address from silicon die ID
sh: omap4-dieid: cannot execute - No such file or directory
So omap4-died binary can not executed on booting
