Re: undefined reference to "socket"
04/14/2008 2:31 PM
post6751
-lsocket is needed for sure.
Can you post your console output after build? (command preceding the
error message and the message).
RE: undefined reference to "socket"
04/14/2008 2:33 PM
post6752
Instead of adding -lsocket to the project->options, try the following:
1) Right click on the project and bring up the Properties ...
2) On QNX C/C++ project, select the Linker Tab
3) From the drop down box, select Extra Libraries
4) Select add, and type socket. Leave the rest as default.
5) Hit apply and rebuild.
That should take care of the error. Failing that, a simple example and the
output from your project would be very helpful.
Cheers,
-Brian
> From: ouss zak [mailto:oussama.zakani@gmail.com]
> Sent: Monday, April 14, 2008 14 21
> To: general-ide
> Subject: undefined reference to "socket"
> hi,
> the project that i m working on reads analog inputs and
> then it should send the data by UDP.
> when i m compiling the project, i get this error :
> "undefined reference to "socket" "
> but i have already included socket.h. I thought at first it
> could be a problem in the order of includes.
> #include <sys/socket.h>
> #include <sys/select.h>
> #include <netinet/in.h>
> #include <sys/types.h>
> #include <netdb.h>
> #include <arpa/inet.h>
> i also tried to add -lsocket in the linker (project->options).
> here's a part of my code :
> sockd = socket(AF_INET, SOCK_DGRAM, 0);
> unsigned short int port = 20000;
> SendTo(sockd, (const char*)TargetHost,
> port,codec.msgBuffer, sizeof(codec.msgBuffer)+1);
> int PCI6025E::SendTo(int sock, const char *host, unsigned
> short int port, const char *buffer, int size)
> struct sockaddr_in addr;
> struct hostent *hp ;
> int v;
> addr.sin_addr.s_addr = inet_addr((const char*)host);
> memset(&addr, 0, sizeof(addr));
> addr.sin_family = AF_INET;
> addr.sin_port = port;
> return sendto(sock, buffer, size, 0, (struct
> sockaddr *)&addr, sizeof(addr));
> If someone could help resolve this problem it will be very
> appreciated.
> Thank you
> http://community.qnx.com/sf/go/post6750
