Forum Topic - Problem while runing application: (5 Items)
Im using QNX development suite ide 4.0.1
i built an application as QNX C project
and just wrote a  printf("hellloworld")
i successfully compiled it
But i donno how to run the application.
When im selectin "Run as" -> "C/C++ QNX QConn"
nothing is coming up
i tried  "Run as" -> "C/C++ Local application"
there also nothing is coming up.
and i tried running "qconn" , its not giving me any putput
please help me
 "qconfig" command  output is
QNX Installations
  Installation Name: QNX Momentics Development Suite 6.3.2
            Version: 6.3.2 x86-only
     Base Directory: /opt/qnx632
           QNX_HOST: /opt/qnx632/host/linux/x86
           QNX_TARGET: /opt/qnx632/target/qnx6
Additional Packages
Re: Problem while runing application
Because your project is a QNX C Project, you need to run it as using QNX qconn configuration. Following are the step to
run it:
1) You need to have a separate machine (called target) running QNX Neutrino O.S., run the "qconn" utility in this target
 machine.
2) In you IDE, create a QNX Target project, enter the same IP address as your target machine.
3) Select the build output binary in your project and select "Run as -> C/C++ QNX QConn". This will open a run
configuration dialog window.
4) Make sure you have the correct target selected, and optionally you can enter additional configuration data like
command arguments and environment variables.
5) If you want to debug your binary, do the same things as above except to select "Debug as -> C/C++ QNX QConn".
Is it possible that i can run , target in same machine itself using a Vmware
Yes, you can use a VM running Neutrino.
If you select Run as C/C++ Location Application ON the binary it would
just run it,
to see output of a program open console view. Window->Show View...
select Console
Attachment: Text elaskavaia.vcf 94 bytes
