06/21/2011 9:13 AM
post86744
Hi, Yakup,
The PRE_BUILD macro inserts actions before the output binary is linked, but not before the sources are compiled.
For that, you can use the PRE_TARGET macro. Add a target name to the PRE_TARGET list to put it ahead of the output
binary in the "all" dependencies.
In your example, you could add the following to your common.mk:
-------- 8< --------
SVN_REV=-D $(shell SubWCRev.exe $(PROJECT_ROOT). ../../Main/SVN.h.tmpl ../../Main/SVN.h)
PRE_TARGET=revnum_output
revnum_output:
@echo Revision Number Output $(SVN_REV).
-------- >8 --------
HTH,
Christian
On 2011-06-21, at 8:38 AM, Yakup Cengiz wrote:
> I have a question about QNX C++ project settings. I need to execute a shell
> script before compiling QNX C++ Project, I added following lines to
> common.mk but I couldn't be successful.
> ../../Main/SVN.h)
> all :
> shell script works well, but it works after compilation, I don't know where
> I missed. Thanks in advance.
> http://community.qnx.com/sf/go/post86742
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>
