Re: Prosess [pid] in timeline (tracelogger in ring mode)
02/12/2008 8:07 AM
post4919
The reason for this is quite simple.
TraceEvents like "CreateProcessName" which the IDE takes the information about process names from, are triggered only
once on tracelogger start/attach to procnto-instr by procnto itself.
If your trace now runs long enough, these events will be overwritten because you're running in "ring mode".
I don't now if QNX has a plan for making process names editable int the IDE, but what you can do, is to append
appropriate "CreateProcessName" events to the tracefile, this is a bit tricky - but it works (we do this for threadnames
on 6.3.0 which has no threadname support).
-hp
