12/13/2007 8:50 AM
post3734
> From: Mario Charest [mailto:mcharest@zinformatic.com]
> Sent: December 12, 2007 6:09 PM
> To: general-ide
> Subject: Re: RE: Two rows
> > > I'm hoping someone will make that suggestion to the Eclipse group.
> > Actually .. you can participate (since QNX can push this, but it is
> > also a general Eclipse functionality) if you would like to and put
> > your comments and feedback directly in here:
> > https://bugs.eclipse.org/bugs/show_bug.cgi?id=168379
> I should have known I was opening a can of worm.
Yes ... but the good news is that you are not alone! The topic
of editor management has a long and exciting political history
within the Eclipse platform development. It goes all the way
back to the 1.0 version where editors used to be linked to the
perspectives. Then in 2.0 that changed to be editors show up in
all perspectives. Then in 3.0 the entire look of Eclipse changed
and with that new styling came new mechanisms for dealing with
the limited editor tab space and policies for recycling editors
that were offscreen. Things like "re-use the same editor for
search results" started showing up in preferences etc.
So ... if you have constructive feedback, it will be well received.
Just goes to show you how coming up with a solution to a seemingly
simple problem can occupy years worth of work.
Thomas
