Forum Topic - Project properties compiling ARM7 and X86 at the same time: (2 Items)
Hello!
I've been working with the emulator and compiling my project with X86. I need now to compile with ARM7 to run my
application on the device. I've changed my project to compile with both options at the same time. I've set the extra
libraries options for each platform in the project properties advanced options.
It seems to me that the ARM7 extra libraries are not saved. When the compilation gets to the linking process, it stops
with an error. When I go back to the extra library options, all the libs included are not there anymore.
Is this a known issue? What should I do to overcome this?
Thank you,
Re: Project properties compiling ARM7 and X86 at the same time
Hi, Hertel,
It sounds like you are working with a QNX C/C++ Project.  What do you
see in the common.mk file after you set the extra libraries for ARMv7?
Do you see, for example,
   LIBS_arm_v7+= ...
or just this
   LIBS_arm+= ...
or something else?  How does the file change after you set the
libraries? (you can use the Compare With Previous from local history
action to see the changes)
Do you see in the C Build Console that the linker command actually
doesn't have the libraries?
Cheers,
Christian
On 31/08/10 10:17 AM, Hertel Brunache wrote:
> Hello!
> Thank you,
> http://community.qnx.com/sf/go/post65182
*Christian W. Damus*
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>;
