Forum Topic - Debugging assembly program on NEON: (19 Items)
I have downloaded the BSP for ARM cortex A8, built it and flashed on the Mistral EVM board.
I have written a program using NEON intrinsic and assembly in C, now I want to debug this program on the target board
using momentics installed on the windows machine or some other method, please let me know what i procedure for the same.
Associations:
post63528:
              Re: RE: Debugging assembly program on NEON - However the same program runs successfully with out any issue(Though the fianl result is not matching with reference code) - Girisha SG
There is no difference to debug a program written in C or assembly. You compile it with debug option turned on and debug
 it using QConn (IP) launch configuration, or Serial launch if you don't have QConn running over TCP/IP.
If you want to debug IPL or Startup, you can use a JTag device and the "GDB hardware debug" option in IDE.
All can be found in this document http://www.qnx.com/developers/docs/6.4.1/ide_en/user_guide/debug.html
From: Girisha SG [mailto:community-noreply@qnx.com]
Sent: Thu 19/08/2010 7:42 AM
To: general-ide
Subject: Debugging assembly program on NEON
Attachment: Text winmail.dat 2.87 KB
I had tried this using momentics 6.5.0 IDE, it was not of much help as it use to crash abruptly/give error sayin illigal
 instruction etc :( after pressing F5 couple of times.
Also it is not shawing d/s register contents properly
Associations:
post63506:
RE: RE: Debugging assembly program on NEON
You must be careful about pressing F5 to step into the code. You don't
want to step into any system binaries (e.g. libc) otherwise you will get
error from gdb that it can't intercept the memory not owned by your
program.
What do you mean not showing register contents properly? Wrong
registers? Program error?
Sent: Thursday, August 19, 2010 9:17 AM
To: general-ide
Subject: Re: RE: Debugging assembly program on NEON
it use to crash abruptly/give error sayin illigal instruction etc :(
General
http://community.qnx.com/sf/go/post63528
Re: RE: RE: Debugging assembly program on NEON
Register contents are wrong and also it is not showing different lanes present in each register(i.e. Each NEON register
is 64 bit and it can be logically devided into multiple lanes)
Re: Debugging assembly program on NEON
If it says illegal instruction - it is illegal instruction. Which can be even true if you use assembly.
You cannot really blame IDE for that. Make sure you have same binary on host and target when debugging, and same shared
libraries (libc versions specifically).
illigal instruction etc :( after pressing F5 couple of times.
code)
Than check that binary and libraries are matching, I bet they don't. Do you see any warning about it in debugger console
 in IDE?
code)
> http://community.qnx.com/sf/go/post63539
I am using BSP supplied by QNX and that is version 6.4.1 and host machine is installed with momentics 6.5.0
I require 6.5.0 for my development as a must requirement.
Does not matter what bsp is for, if it compiles. What target is running? If it is 6.4.1 debugging won't work.
Also debugger does not have support for neon registers I think, you can ask about core tool forum about it.
> http://community.qnx.com/sf/go/post63544
It should have support for NEON registers. Check gdb revision (to make
sure you are not picking up wrong gdb).
If you do "info all-registers", what does gdb display?
> > General
> http://community.qnx.com/sf/go/post63550
It shows all the registers(including S registers) but it does not show different lanes within each register i.e. Each 64
 bit neon register can be devided into multiple lanes depending on the data size, but with IDE it is not showing
different lanes
Could you try "info all-registers" from gdb console?
64 bit neon register can be devided into multiple lanes depending on the data size, but with IDE it is not showing
different lanes
> http://community.qnx.com/sf/go/post63673
I could not recompile the BSP released for 6.4.1 as I was getting an error
"error: operator '==' has no left operand" for the below section of code
/* Leave deprecated sections enabled for right now */
#if !defined(ENABLE_DEPRECATED_SYSPAGE_SECTIONS)
# define ENABLE_DEPRECATED_SYSPAGE_SECTIONS
#elif (ENABLE_DEPRECATED_SYSPAGE_SECTIONS == 0) /* Error for this line */
# undef ENABLE_DEPRECATED_SYSPAGE_SECTIONS
#endif
I had commented the #elif part and I could build the code.
With this image I am not seeing any abrupt behaviour till now !
> #endif
Remove the copy of syspage.h from the BSP. This is explained on the page
for building 6.4.x BSPs on 6.5.0 page on the BSP page.
Ryan Mansfield
I am getting the following warning
warning: Host file C:/QNX650/target/qnx6/armle-v7/usr/lib/ldqnx.so.2 does not match target file /usr/lib/ldqnx.so.2
steps to get away from it ???
Is your target running 6.5.0? If not then you have a mismatch since you are using the 6.5.0 version on your host side.
Either update your target to the same release of your host, or re-target your IDE to use the same release of your target
For the later, for example, if your target is running 6.4.1, you need to install the 6.4.1 SDP on your host and change
your IDE to use 6.4.1 from "Preferences -> QNX -> Select Installation" drop down list.
Sent: Tue 24/08/2010 7:42 AM
To: general-ide
Subject: Re: Debugging assembly program on NEON
Attachment: Text winmail.dat 2.75 KB
Yes I am using momentics 6.5.0 on the host side. I have re-built the BSP for OMAP3530 Mistral EVM by QNX(It was released
 for momentics 6.4.1) using 6.5.0 tool chain and usaing the same image on the target but still I am getting the above
said warning and debugging fails in inadverant ways ...
I would like to go for 6.5.0 on the target as well, please suggest me the steps.
