Forum Topic - Can't install subversive plugin: (7 Items)
When trying to install the subversive plug-in under IDE 4.00 and Tau I get:
JDT Ignore Extensions (Optional) (1.0.5) requires plug-in "org.eclipse.jdt.core".
Suggestions?
RE: Can't install subversive plugin
> From: Mario Charest [mailto:mcharest@zinformatic.com]
> Sent: November 22, 2007 3:48 PM
> To: general-ide
> Subject: Can't install subversive plugin
> and Tau I get:
> Suggestions?
Sounds like you are installing the optional part of the subversive
plugin that has a tighter binding with the Java development environment
which we don't provide.
Options include:
1) Don't install that component from subversive
2) Install the Java development tools
The side benefit of 2) is that you can start writing custom plugins
and extending and enhancing your IDE experience ... it is like emacs
but without all of the pesky (((((
Hope this helps,
 Thomas
Re: RE: Can't install subversive plugin
> Hope this helps,
Almost, just have to figure out a way to do that without disrupting my current setup.
>  Thomas
Unselect JDT Ignore Extension feature?
If you don't have JDT you probably don't need it...
And where would that option be?
RE: RE: Can't install subversive plugin
When you install subversion plugin in update site you can pick
which features to install, so don't pick this feature... It should have a
checkbox near it. Or how are you trying to install it?
Re: RE: RE: Can't install subversive plugin
I see it now, I was not expanding the list deep enough.
Thanks!
