Forum Topic - make error for BSP-ATMEL-AT91SAM9G45-EK-src: (3 Items)
My controller is BSP_ATMEL_AT91SAM9G45-EK-src and I am trying to built keypad driver which is based on GPIO module..
But every time I am getting same error.
/***************error***************/
make: *** [install] Error 2	BSP-ATMEL-AT91SAM9G45-EK-src		line 0	C/C++ Problem
make[1]: *** [install] Error 2	BSP-ATMEL-AT91SAM9G45-EK-src		line 0	C/C++ Problem
make[2]: *** [install] Error 2	BSP-ATMEL-AT91SAM9G45-EK-src		line 0	C/C++ Problem
make[3]: *** [install] Error 2	BSP-ATMEL-AT91SAM9G45-EK-src		line 0	C/C++ Problem
make[4]: *** [install] Error 2	BSP-ATMEL-AT91SAM9G45-EK-src		line 0	C/C++ Problem
make[5]: *** [install] Error 2	BSP-ATMEL-AT91SAM9G45-EK-src		line 0	C/C++ Problem
make[6]: *** [C:/test1/BSP-ATMEL-AT91SAM9G45-EK-src/src/hardware/key/master/arm/le/key-master] Error 1	BSP-ATMEL-
On further I found that "key-master.o" and "key-master.pinfo" file is not creat in ../master/arm/le
Changes were made in common.mk , project.xml files
Still the same error is occuring..
Please let me know where is the problem.
Do I missing something
Re: make error for BSP-ATMEL-AT91SAM9G45-EK-src
This does not show the actual error, can you copy a log from the build
console please
On 11/08/10 09:50 AM, gunjan sethi wrote:
> Hello,
> http://community.qnx.com/sf/go/post62621
Thanks for your quick reply.
here is the console log..
/************************console log********************/
Warning: ttfFFcore.so not found at given absolute location.
	Item host location: C:/QNX641/target/qnx6/armle/lib/dll
	Item target location: /lib/dll/font
	Item target name: ttfFFcore.so
Warning: PHFcore.so not found at given absolute location.
	Item target name: PHFcore.so
Warning: FCcore.so not found at given absolute location.
	Item target name: FCcore.so
Warning: devc-serdebug not found at given absolute location.
	Item host location: Z:/test1/BSP-ATMEL-AT91SAM9G45-EK-src/src/hardware/devc/serdebug/arm
	Item target location: /proc/boot
	Item target name: devc-serdebug
Warning: devc-serusart not found at given absolute location.
	Item host location: Z:/test1/BSP-ATMEL-AT91SAM9G45-EK-src/src/hardware/devc/serusart/arm
	Item target name: devc-serusart
Warning: fontopts not found at given absolute location.
	Item host location: C:/QNX641/target/qnx6/usr/photon
	Item target location: /usr/photon/font_repository
	Item target name: fontopts
Warning: pcterm12.phf not found at given absolute location.
	Item target name: pcterm12.phf
Warning: pcterm14.phf not found at given absolute location.
	Item target name: pcterm14.phf
Warning: pcterm20.phf not found at given absolute location.
	Item target name: pcterm20.phf
Warning: phcursor.phf not found at given absolute location.
	Item target name: phcursor.phf
Warning: tt2001m_.ttf not found at given absolute location.
	Item target name: tt2001m_.ttf
Warning: tt2002m_.ttf not found at given absolute location.
	Item target name: tt2002m_.ttf
Warning: tt2003m_.ttf not found at given absolute location.
	Item target name: tt2003m_.ttf
Warning: tt2004m_.ttf not found at given absolute location.
	Item target name: tt2004m_.ttf
Warning: tt2009m_.ttf not found at given absolute location.
	Item target name: tt2009m_.ttf
Warning: tt2011m_.ttf not found at given absolute location.
	Item target name: tt2011m_.ttf
Warning: default.pal not found at given absolute location.
	Item target location: /usr/photon/palette
	Item target name: default.pal
Warning: en_US_101.kbd not found at given absolute location.
	Item target location: /usr/photon/keyboard
	Item target name: en_US_101.kbd
Warning: wm.cfg not found at given absolute location.
	Item host location: C:/QNX641/target/qnx6/usr/photon/config
	Item target location: /usr/photon/config/wm
	Item target name: wm.cfg
Warning: wm.menu not found at given absolute location.
	Item host location:...
