Forum Topic - How can I create build container files quickly?: (6 Items)
I have a question that came from a developer at my company.  He is trying to quickly create a build container for his
projects by copying a container for another project and modifying it for his project.  He has run into a problem when
trying to update the container for his project.  Let's say the container references the following projects:
CommonLib1
CommonLib2
CommonLib3
OldProject1
OldProject2
NewProject1
NewProject2
This is just a small example.  We have a lot more projects than listed above.  We would like to use the IDE to update
the container file (com.qnx.tools.ide.qde.core.prefs).  There are several make configurations in this build container.
In this example, the new project does not use "OldProjectX" so those need to be removed.  He starts by importing the QNX
 build container to his workspace.  He unchecks the missing projects (i.e. OldProject1, OldProject2) so that the IDE
does not try to import the missing projects.
The .prefs file still needs to be updated.  So he edits the make configuration from the IDE.  After removing OldProject1
 and OldProject2 from the make configuration window, he clicks OK but sees an error window: "Error saving updated
project configurations:null".  The .prefs file is not updated although the make configuration shows the changes he made.
  If we restarts the IDE, his changes are gone, and the make configuration is refreshed from the .prefs file.
We tried manually deleting the OldProjectX xml entries in the .prefs file, but that causes the container file to be
corrupted because the projects are not in sequence.
Questions:
1) Is this the best way to create build containers quickly?  Is there another alternative that involves container
templates?  We would like to avoid creating the build container from scratch, as it involves many projects, many make
configurations, and tedious variant configurations.
2) What caused the save error?  Is there a workaround for this error?
The save error was observed on IDE 4.6.1 and IDE 4.7 (packaged with QNX 6.5.0 release).
Rex
Re: How can I create build container files quickly?
Hi, Rex,
See some comments in-line, below.
HTH,
Christian
On 04/08/10 01:47 PM, Rex Lam wrote:
> Hello,
> CommonLib1
> CommonLib2
> CommonLib3
> OldProject1
> OldProject2
> NewProject1
> NewProject2
OldProject1 and OldProject2 from the make configuration window, he clicks OK but sees an error window: "Error saving
updated project configurations:null".  The .prefs file is not updated although the make configuration
This is a bug.  The property page for the configuration should
understand that configurations are being removed that don't exist, anyway.
>   shows the changes he made.  If we restarts the IDE, his changes are gone, and the make configuration is refreshed
Can you provide more specifics of the corruption?  There is no XML in
the container project settings (.prefs file).  If you are removing
elements from the sequence, you should shift down the sequence numbers
of any subsequent entries so that there are no gaps in the sequence.
Look for the ".../build_position=<#>" entries in the file.
> Questions:
Editing the file "directly" is the only way, owing to the bug in the
attempt to remove non-existent projects from the configuration.  It
should be feasible to do this, as long as the sequence is maintained.
No, there is no work-around.  It's just a programming error in the
property page.
> Rex
> http://community.qnx.com/sf/go/post61608
*Christian W. Damus*
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>;
Christian,
Thank you for creating a PR to save the modified container configuration.  I apologize for the misinformation.  It is
not XML, as you pointed out.  The problem had to do with the incorrect 'build_position' entries after the old projects
had been deleted.  I was hoping the IDE would be able to re-sort the projects so that it is not a manual process of
updating the build position.  That did not happen and effectively "corrupted" the .prefs file since the IDE cannot use
it in that state.  It is cumbersome to update by hand the build positions in five or more make configurations, each with
 about 20 projects.
Is it possible for the IDE to also remove gaps in the build position sequence (effectively correcting errors in the .
prefs file)?  This feature would save us some time.
Rex
Hi, Rex,
Replies in-line, below.
Cheers,
Christian
On 04/08/10 05:55 PM, Rex Lam wrote:
> Christian,
No apologies are needed.  XML would be easier to work with than a Java
properties file.  :-)
> It is not XML, as you pointed out.  The problem had to do with the incorrect 'build_position' entries after the old
projects had been deleted.  I was hoping the IDE would be able to re-sort the projects so that it is not a manual
process of updating the build position.  That did not happen and effectively "corrupted" the .prefs file since the IDE
cannot use it in that state.  It is cumbersome to update by hand the build positions in five or more make configurations
, each with about 20 projects.
Indeed.  Scriptable, I suppose, by one better versed in Perl than I.
This would naturally be a part of the fix for the PR.  It shouldn't
matter the actual indices; only the ordering.  The PR links to this
conversation, so I won't lose any information.
> Rex
> http://community.qnx.com/sf/go/post61651
I tried the experimental release of IDE 4.7.1 today.  It has the fix for this problem.  I want to thank you for fixing
it so quickly.  I didn't expect such a quick turnaround so it was a pleasant surprise.  Thanks again.
Rex,
I have raised PR 78513 to track the bug in saving the modified container
configuration.
Cheers,
Christian
