Forum Topic - Momentics IDE error while doing Debug: Page 1 of 2 (38 Items)
I am trying to Debug a C project, and do a QConn onto a target system.
My IDE environment is Momentics 6.3 with SP3, and IDE 4.0. The target is runtime neutrino 6.3.
I get the error shown in the attachment, and the thread suspends with a SIGSEV.
I have included a view of the Disassembly window, if it helps.
The Run configuration executes properly on the target.
Attachment: Image QNXDebuggerError.JPG 137.22 KB
Re: Momentics IDE error while doing Debug
Did you program try to step into the kernel memory space, e.g. pointer
error to any library function? Your program got SIGSEGV because it tried
to make an invalid memory reference.
Also make sure you compile your program with debug option (-g) so you
have symbol information in the debug view. Try to put a break point in
"main()" to start debugging.
Reply-to: post59634@community.qnx.com
To: general-ide <post59634@community.qnx.com>
Subject: Momentics IDE error while doing Debug
Date: Fri, 16 Jul 2010 07:57:32 -0400 (EDT)
General
http://community.qnx.com/sf/go/post59634
where can i insert the -g option, which part of the build window or properties?
If it's a QNX C project, you can open the project properties -> Build
Variants, select the "debug" variant.
If it's a standard make project, you can add "-g" option to the CCFLAGS
in your make file.
You can reference the IDE user's guide for the 6.3.2 release for more
information on build and debug options:
http://www.qnx.com/download/download/16839/ide_user_guide.pdf
Reply-to: post59652@community.qnx.com
To: general-ide <post59652@community.qnx.com>
Subject: Re: Momentics IDE error while doing Debug
Date: Fri, 16 Jul 2010 10:48:50 -0400 (EDT)
General
http://community.qnx.com/sf/go/post59652
already the debug build variant has been selected.
do i still need to do a -g option?
Is there anything else i could try, in order to get this working?
Did you put a break point at the beginning of your "main()"? Did the
program stop at that break point?
Reply-to: post59661@community.qnx.com
To: general-ide <post59661@community.qnx.com>
Date: Fri, 16 Jul 2010 11:49:25 -0400 (EDT)
General
http://community.qnx.com/sf/go/post59661
yes it did, and it seems these errors take place, even before control reaches main().
This is strange. Can you attach your project to this post?
Reply-to: post59666@community.qnx.com
To: general-ide <post59666@community.qnx.com>
Date: Fri, 16 Jul 2010 12:12:17 -0400 (EDT)
General
http://community.qnx.com/sf/go/post59666
I am doing a Qconn onto a QNX environment in a virtual machine. Could this be a cause for this error?
I need to try it on a dedicated QNX box and see if it makes a difference.
just want to make sure, should i be using the QN GDB Debugger?
any additions to Main or Shared Libraries under Debugger tab?
Yes if you debugging with shared library you need to add shared library
paths to Debugger tab. Also they have to be compiled with -g.
See also debugger FAQ:
http://community.qnx.com/sf/wiki/do/viewPage/projects.ide/wiki/DebuggerFAQ
> http://community.qnx.com/sf/go/post59767
this is my doubt, where do i insert the -g, as part of which statement and where?
tried with a dedicated QNX box, and still have the same error...
wel,l i checked on a dedicated QNX box, and still get the same error...
the project uses static libraries, do i have to move then (.a) to qnx6/x86/lib and usr/qnx632/target?
Pp
----- Original Message -----
To: general-ide <post59863@community.qnx.com>
Sent: Mon Jul 19 15:42:07 2010
General
http://community.qnx.com/sf/go/post59863
ok, made some progress, and found out where the execution is coming to a halt.
I have attached a screen shot.
Also i replaced ntox86-gdb.exe ver 6.7 (did a backup of the old notx86-gdb file, cuase could not determine which version
 it was), to get more info, and found in the console window a mismatch of the host and target libc.so file.
How can i solve this issue? Where do i have to do the change? Where can i donwload the neccessary file, and how do i
install it?
console window:
MsgNak received - resending
Remote target is little-endian
attach 1376294
Setting Dynamic-Linker Breakpoint based on C:/QNX630/target/qnx6/x86/usr/lib/ldqnx.so.2
warning: Host file C:/QNX630/target/qnx6/x86/usr/lib/ldqnx.so.2 does not match target file /usr/lib/ldqnx.so.2
0xb0334792 in ?? ()
mi_cmd_var_create: unable to create variable object
i did a qconfig on my target and got the following information:
Installtion Name: QNX Neutrino RTOS x86 Runtime Kit 6.3.2
Version: 6.3.2
Base Directory: /
QNX_HOST: /
QNX_TARGET: /
should there be a path for QNX_HOST and QNX_TARGET?
if so, how do i set the path?
Appreciate the help..want to finish this ASAP...
RE: Momentics IDE error while doing Debug
I don't see the screen shot, did you forget to attach it?
You have mismatching libc because you are running 6.3.0 SP3 on host but 6.3.2 on target. You can contact your QNX sales
rep for an upgrade to 6.3.2. But I suspect this is the root cause of your problem.
Have you tried the latest gdb? you can download it from this link http://community.qnx.com/sf/frs/do/listReleases/
projects.toolchain/frs.gdb
Another possibility is error in your code. Going back to your first post that your program got SIGSEGV and now you got "
mi_cmd_var_create: unable to create variable object", you can check in the "Breakpoint" view to see where you put your
breakpoint. Remove all other breakpoints except the one at your "main()".
From: Rashid Mirza [mailto:community-noreply@qnx.com]
Sent: Tue 20/07/2010 7:41 AM
To: general-ide
install it?
console window:
attach 1376294
0xb0334792 in ?? ()
Version: 6.3.2
Base Directory: /
QNX_HOST: /
QNX_TARGET: /
General
http://community.qnx.com/sf/go/post59917
Attachment: Text winmail.dat 3.65 KB
Re: RE: Momentics IDE error while doing Debug
fine i will look into preparing my host with qnx 6.3.2 sp3.
Is there a way to obtain what my existing installation is on the host, i.e the version on QNX?
i have attached screen dump now.
Attachment: Image Debug_moreinfo.JPG 139.67 KB
RE: RE: Momentics IDE error while doing Debug
You need 6.3.2, not "6.3.2 sp3". There is no "sp3" for 6.3.2.
I don't understand your question of "existing installation is on the host". You are going to install 6.3.2 to your host
and run IDE from 6.3.2. By default it installs to "C:\QNX632" directory so it will not remove your existing installation
 of 6.3.0 SP3.
Sent: Tue 20/07/2010 8:36 AM
To: general-ide
Subject: Re: RE: Momentics IDE error while doing Debug
Attachment: Text winmail.dat 2.73 KB
Re: RE: RE: Momentics IDE error while doing Debug
ok, a installation to another directory is good, let me try and i will get back
Looking at your screen shot, it seems like your program is not compiled with debug info. Did you compile it with "-g"
option?
since i am using the IDE for compilation, i dont know where i have to insert the -g option. which part of the IDE?
i would like to add, i had similar error (as my first attachment) when i checked Debug with a dedicated QNX box, but
that was running 6.3.0 SP3, therefore it was matching my host which was also 6.3.0 with SP3.
If you using debug variant it is inserted automatically. You can check
that but looking at the build output on console - you will see full
command line, make
sure it includes -g. Answer on your question about where to insert -g
depends on what type of project you are using. Is it qnx project?
> http://community.qnx.com/sf/go/post59941
