Re: RE: RE: Help Contents Missing from QNX650 Momentics IDE
07/09/2010 10:15 AM
post59075
> Ok good to know. Is there an "Eclipse" directory under C:\QNX650\target\qnx6\
> usr\help?
Yes. There's also a plugins folder under that, "C:\QNX650\target\qnx6\usr\help\eclipse\plugins" that contains 65 "com.
qnx.doc.*" files. I peeked inside the *neutrino_lib_ref*\doc.zip file and saw lots of topic HTML files.
> For testing purpose, rename your C:\Document and Settings\<your_login_id>\momentics\4.7, and
> restart your IDE, pick a brand new workspace, see if you can get the other
> docs? If not, please attach your log file under your <workspace_dir>\.metadata directory
> called ".log"
Yes, I can get the other docs with a brand new workspace. I can also get the docs with the old workspace. I guess this
means the trouble is somewhere in the renamed "C:\Document and Settings\<my_login_id>\momentics\4.7"?
I restored the old "C:\Document and Settings\<my_login_id>\momentics\4.7", restarted the IDE, picked a brand new
workspace, and the problem returned. I've attached the ".metadata\.log" file for this test.
However, unless you say otherwise, I'll continue working with the newly created "C:\Document and Settings\<my_login_id>\
momentics\4.7", and consider the issue closed.
Thanks for your help.
| Attachment: |
.log
3.46 KB
