Forum Topic - no build variants: (2 Items)
no build variants
I have two projects in my IDE, on QNX Momentics 6.3, SP3.
One of the projects, has X86 as the build variant, and compiles successfully.
On the other project:
a) goto project properties
b) select build variants and chose the desired platform (x86 in my case)
c) press apply
try to build, and it says: ***gslib: no active variants to build
go back to project properties, and i find that my selection on build variants has gone, i select again, apply, and again
 its gone.
why is my selection on build variant, not being saved in the properties window? Why does it disappear, as soon as i exit
The software is licensed, the other project seems to work, so why not this one?
I have quit from the momentics application, and tried, its the same.
Re: no build variants
Hi, Rashid,
Did this just start happening, recently?  If so, what changed in your
environment at about the same time?
How does the structure of the problematic project compare to the one
that works?  Does it have, for example, additional levels of directory
nesting?  Is there any difference in the common.mk files that doesn't
look right?
Are you using a source control system that requires explicit checkout?
(e.g., ClearCase)  Anything else that might prevent the IDE from
creating the x86 directories in the project?  Does the project, in fact,
have the correct x86 directories?
Are there any error messages in the workspace log file?  Perhaps you can
send it to me, and I'll have a look at it.  It is file named .log in the
.metadata/ directory in your workspace directory.
Cheers,
Christian
> c) press apply
again its gone.
exit the properties window?
> http://community.qnx.com/sf/go/post58287
*Christian W. Damus*
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>;
