Re: Creating system builder project from existing build file and
search paths
06/28/2010 4:28 PM
post58008
search paths
Hi, John,
The BSP import wizard already did that for you in the System Builder
project that it created.
Do you need to create a second System Builder project, or can you just
use the one that the wizard created? If you do need a second project,
you can copy the .sysbldr_meta file from the project that the import
wizard created into your new System Builder project.
HTH,
Christian
On 28/06/10 04:22 PM, John Pruitt wrote:
> I am using the 4.6.0 Momentics IDE.When I import a BSP from a local archive it creates 2 projects. The source for the
BSP and a system builder project. If a try to create a system builder project from the "build" file that is in the BSP
source, a system builder project is created but it is missing a bunch of search path entries and the resulting system
builder project is essentially useless. It is too hard to add all the missing search paths.
> Is there anyway to easily create a usable system builder project from the "build" file without having to do a full
import from a local archive file?
> Thanks.
> http://community.qnx.com/sf/go/post58007
*Christian W. Damus*
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>
