Forum Topic - Build in Momentics 6.4.1 vs Command line: (3 Items)
I am trying to build a QNX project from the command line instead of the Momemtics IDE to script the build of several c/c
++ together. My projects are using the recursive makefiles and build successfully in the Momentics IDE. However, when
running make from the command line (Windows XP Pro) the extra include paths are not added to the qcc calls. See below:
From command line:
C:/QNX641/host/win32/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O          -DNDEBUG   -I. -IC:/
Perforce/src/ConfigProc/x86/o -IC:/Perforce/src/ConfigProc/x86 -IC:/Perforce/src/ConfigProc -IC:/QNX641/target/qnx6/usr/
include     -DBUILDENV_qss  C:/Perforce/src/ConfigProc/ConfigProc.c
In Momentics:
Perforce/src/ConfigProc/x86/o -IC:/Perforce/src/ConfigProc/x86 -IC:/Perforce/src/ConfigProc -IC:/Perforce/includes -IC:/
QNX641/target/qnx6/usr/include     -DBUILDENV_qss  C:/Perforce/src/ConfigProc/CRC.c
When run from the command line the extra include path "-IC:/Perforce/includes" is not added. This is defined in the
common.mk as "EXTRA_INCVPATH+=$(PROJECT_ROOT_includes)".
I was also curious about the content of the autogenerated file called out in the make command: make -k CPULIST=x86
EXCLUDE_VARIANTLIST=be/g/ all --file=C:/DOCUME~1/mpierce/LOCALS~1/Temp/QMakefile127723839573959888.tmp
Re: Build in Momentics 6.4.1 vs Command line
Hi, Michael,
See some replies in-line, below.
HTH,
Christian
/c++ together. My projects are using the recursive makefiles and build successfully in the Momentics IDE. However, when
>  From command line:
> In Momentics:
You will need to define a make variable for this yourself, as you don't
have the IDE in this scenario to inject it for you.  You can do this via
   make PROJECT_ROOT_includes=C:/Perforce/includes all
or, if you have a number of such PROJECT_ROOT_xyz variables, you can put
them in a makefile (say, "C:/DOCUME~1/mpierce/projectroots.mk") and do
   make MAKEFILES=C:/DOCUME~1/projectroots.mk all
Heh heh.  As it happens, this temporary makefile is responsible for
bootstrapping the project build by, among other things, defining the
PROJECT_ROOT_xyz variables required by the project according to its
inter-project dependencies.
> http://community.qnx.com/sf/go/post57567
*Christian W. Damus*
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>;
I managed to resolve this by making a project at the top level directory that recursively builds all of the projects
below. This wasn't possible with previous versions of Momentics/Eclipse so I dismissed this as a solution but it works
with ide 4.6. Thanks for the reply.
Michael Pierce
ViaSat Inc.
1725 Breckinridge Plaza
Duluth, GA 30096
(678) 924-2896
michael.pierce@viasat.com
