Forum Topic - Quick Jump to File: (3 Items)
Quick Jump to File
I¹d like to be able to jump to a file quickly without having to use the
mouse.  It sounds like CTRL-SHIFT-R should do it, but that doesn¹t do
anything for me.
Any suggestions?
Dan
Dan Cardamore   <dcardamore@qnx.com>
AW: Quick Jump to File
Try using SHIFT-CTRL-L
that shows you a context dependant popup of all available keyboard shortcuts.
CTRL-SHIFT-R opens the eclipse "Open Resource" Dialog
Maybe your are within a context where CTRL-SHIFT-R is not mapped
/hp
>Von: Dan Cardamore [mailto:community-noreply@qnx.com]
>Gesendet: Mittwoch, 2. Juni 2010 04:32
>An: general-ide
>Betreff: Quick Jump to File
>to use the mouse.  It sounds like CTRL-SHIFT-R should do it,
>but that doesn¹t do anything for me.
>Any suggestions?
>Thanks,
>Dan
>General
>http://community.qnx.com/sf/go/post55911
Re: AW: Quick Jump to File
Hi, Dan,
Further to Hans-Peter's suggestion, if you see that the Open Resource command is not mapped to any keybinding, then you
can customize your perspective to add it.  The "Window -> Customize Perspective..." menu opens a dialog in which you can
 add the group of resource navigation commands including Open Resource to your perspective.
HTH,
Christian
	/hp
		An: general-ide
		Any suggestions?
		Dan
		Dan Cardamore   <dcardamore@qnx.com> <mailto:dcardamore@qnx.com>;
		General
	General
	http://community.qnx.com/sf/go/post55918
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems <http://www.qnx.com/>;
