04/18/2010 8:29 PM
post51999
Thanks Christian
This is less than ideal, there would be no way (well I'm sure there's a way, but not easy) to know if the previously
created one-off workspace is valid...i.e. has anyone added a project to the workspace?
Due to this and other issues (PRE_TARGET causes command line to not build) I'm considering resorting to automating IDE
itself via the GUI (AutoHotKey or something similar). I REALLY don't want to go down this path, for what should be
obvious reasons. But at this point I'm not sure I have any robust options.
Cheers
Adrian
> Hi, Adrian,
> Note that you will only have to import your System Builder project (and its
> dependencies) into the workspace once. Thereafter, you can simply replace the
> contents of all projects with your checkout in each automated build. There
> shouldn't be any need to import into the workspace again (unless, of course,
> you add more projects).
> HTH,
> Christian
> On 12/04/10 02:32 AM, Adrian Higgins wrote:
> This seems like a great tool...IF you have manually imported all your
> projects into an IDE workspace.
> What I want is to automate building each image from source.
> I want to be able to checkout the projects and build the image.
> I do not want to have to first manually import all the projects into an IDE.
> One way around this is to version control the .metadata directory.
> This seems like a very bad idea.
> Any further thoughts on this issue?
> http://community.qnx.com/sf/go/post51447
> Christian W. Damus
> Software Developer, IDE Team
> QNX Software Systems <http://www.qnx.com/>
