Forum Topic - Missing Data in Malloc Information View: (3 Items)
When looking in the malloc information view on most of our application,  they will 0s in the Total Heap/Calls Made, Core
 Requests section, but the Byte Range stuff is ok.
At first I though it was a problem with the way librairies are linked, but other applications will be ok and they are
all build with the same makefile.
Any idea?
Re: Missing Data in Malloc Information View
So what is different between projects that do work from ones that don't?
Does libc linked statically to any of this?
RE: Missing Data in Malloc Information View
> Sent: Monday, March 01, 2010 3:19 PM
> To: general-ide
> Subject: Re: Missing Data in Malloc Information View
> don't?
I looked for a difference that could explain it, but nothing.  I check with objdump -x and they all need the same shared
 object.  Maybe they aren't loading them in the same order? Just check and they are loaded in the same order.
Nope, it's listed in the objdump -x output.  However isn't it odd that it doesn't show when using DL_DEBUG=1, that's
true for QNX's apps as well.
Update:
I made some more test and the code that fails makes use of our static library while the code that is ok doesn't.  That
being said they are all linked with the same argument. That library has some C++ object that have their constructor
called before main() maybe that has something to do with it, I'll keep investigating.
> http://community.qnx.com/sf/go/post48557
