Forum Topic - Profiling an application: (4 Items)
Dear
I am currently trying to profile an application.
THis application is not compiled with the IDE I only import the executable file.
I have compiled it with the following options
Compiler: -finstrument-functions
Linker: -lprofilingS
Then in the profiling options I have added:
   Tools / Application profiler
   Tools / Memory Analysis.
When I run the application I can see the "Executation time" chart updating during the run but I do not have anything in
the "Allocations" chart
Any idea on what can be wrong or missing here?
Thanks in advance.
Attachment: Image untitled.JPG 143.71 KB
Re: Profiling an application
I succeeded to generate a rmap file with the following command line without any change in my compilation option.
 Compiler: no -finstrument-functions option
 Linker: no -lprofilingS option
but when I load the file in IDE I have some issues due to
    "unexpected token ENDAPPSTREAM at line xxxx"
if I remove them then it loads
In a test application I only do a malloc(128)
screenshot: http://yfrog.com/0ialloc128j
but as you can see on the picture there are other allocation before.
I do not succeed to see from which file/function the allocation is done
ENDAPPSTREAM - you IDE is older then profiling library looks like
Memory Analysis - other allocation comes from libc. Looks like you app
was not compiled with debug info -
otherwise you could have filtered it by binary/file name.
> http://community.qnx.com/sf/go/post48397
I suggest not to run two tools at the same time
> Dear
in the "Allocations" chart
> Thanks in advance.
> http://community.qnx.com/sf/go/post48302
