Forum Topic - Why Running? not working for SigEventPulse as reason? End of chain detected: (3 Items)
I'm looking at the "Why Running?" view in the IDE, and have flash devg-gpuEventHandler Owner selected and the reason is
io-display OpenVG-G12-IST type "SyncCondvarSignal Enter"
Then I go to the previous running event, which has owner thread "io-display OpenVG-G12-IST"
I click "Find Running/Reason" in the Why Running View and "End of chain detected" is all that appears.  The event
immediately before the Running event is "Sigevent Pulse," which follows Interrupt 0x10 (IPU function interrupt) io-
display Handler Exit, Interrupt 0x10 Exit
I suspect the "Running Reason" is that the ISR does a sigevent, which leads to the sigevent Pulse, no? Why wouldn't this
 appear in the view's list?
Thanks!
Re: Why Running? not working for SigEventPulse as reason? End of chain detected
Andrew,
Most likely it is simply that this scenario is not covered in the algorithm Why Running uses to determine the running
reason. Please raise a PR so that we can investigate.
David
> gpuEventHandler Owner selected and the reason is io-display OpenVG-G12-IST
> OpenVG-G12-IST"
> detected" is all that appears.  The event immediately before the Running event
> -display Handler Exit, Interrupt 0x10 Exit
>  the sigevent Pulse, no? Why wouldn't this appear in the view's list?
> Thanks!
RE: Why Running? not working for SigEventPulse as reason? End of chain detected
Okay, sounds good
Thanks David
Andrew Sherk
QNX Software Systems
asherk@qnx.com
From: David Cummings [mailto:community-noreply@qnx.com]
Sent: Wednesday, February 24, 2010 12:02 AM
To: general-ide
Subject: Re: Why Running? not working for SigEventPulse as reason? End
of chain detected
Andrew,
algorithm Why Running uses to determine the running reason. Please raise
David
