Forum Topic - IDE runs a little on 64bit system: (3 Items)
I'm running an Ubuntu 9.10 and installed the IDE including the latest update to 4.7
Now I'm able to start the IDE and can use my old workspace, everything looks fine until I try to add a new project,
build a project or anything else which includes some kind of wizard popping up.
The wizards show correctly, I can change and set the contents but the (next >) and (finish) buttons won't work. They are
 unghosted correctly when all data is in but when I click, they just change the bevel but the wizard doesn't change.
Clicking the (cancel) button twice will end the wizard and I'm back on step one.
The console shows a bunch of messages about mismatched libraries, so I guess the IDE runs in ia32 mode and tries to open
 someof the 64 bit libraries.
What confuses me is the fact that the standard IDE (4.6) worked flawless with Ubuntu 8.04 64Bit.
Will there be a 64Bit version of the IDE?
Thanks and greetings,
    bweb
/usr/lib/gio/modules/libgioremote-volume-monitor.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgioremote-volume-monitor.so
/usr/lib/gio/modules/libgiogconf.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgiogconf.so
/usr/lib/gio/modules/libgvfsdbus.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
Re: IDE runs a little on 64bit system
Hi, Bjoern,
This is the change in the GTK API in GTK 2.18 that caught Eclipse SWT
off-guard.  There is a work-around:  in your run_qde.sh script, set this
environment variable:
  export GDK_NATIVE_WINDOWS=1
before launching the qde launcher.
We expect to adopt a fix from the Eclipse Platform in time for the IDE
release; stay tuned.
The wizard button problems are not related to 64-bit or lbrary
compatibility.  I don't know whether the libraries you indicate are
critical to the functioning of the IDE.  Let's see how far you get with
the GTK work-around  :-)
Cheers,
Christian
On Tue, 2010-02-09 at 06:01 -0500, Bjoern Weber wrote:
> Hello,
are unghosted correctly when all data is in but when I click, they just change the bevel but the wizard doesn't change.
open someof the 64 bit libraries.
>     bweb
> http://community.qnx.com/sf/go/post46884
Hello Christian,
> before launching the qde launcher.export GDK_NATIVE_WINDOWS=1
Awesome! Now even the 4.6 IDE is working fine and even the 64Bit warnings went away. Just what I needed to keep on
working on my desktop.
  Bjoern
