Forum Topic - Using C++ tr1 extensions: (5 Items)
I am interested in using the c++ tr1 extensions.
I am having problems configuring a QNX C++ project to use these extensions.
tr1 is found in $(QNX_TARGET)/usr/include/c++/4.3.3
So...I add this path to the Include path, but the compiler complains:
bits/c++allocator.h: No such file or directory	allocator.h
as well as other files in bits/ it can't find.
The specific files bits/xxx.h are in a target specific subdirectory. I surmise I need to add some sort of target
specific info to my project, but I don't know what that is.
I am using Momentics 4.6.1 and, of course, qcc 4.3.3. Target is only x86 at this time.
Thanks.
Test Program:
#include <cstdlib>
#include <iostream>
#include <tr1/tuple>
	std::cout << "Test using TR1 extensions" << std::endl;
	return EXIT_SUCCESS;
Re: Using C++ tr1 extensions
Hi, Keith,
If your QNX C++ project targets only one platform (e.g., x86), then you
can just add
  $(QNX_TARGET)/usr/include/c++/4.3.3/i386-pc-unknown-nto-qnx6.4.0
to your "extra include paths" property in the project settings.
When you do add other targets to your project, then you will need to use
the "Advanced >>" button in the Project Properties dialog to set a
different include path per platform.  In the platform picker at the left
side of the dialog choose a target platform and set the appropriate
include path like the one above.  Make sure that the "All" selection
doesn't have any target-specific include path.
HTH,
Christian
> Thanks.
> Test Program:
> #include <cstdlib>
> #include <iostream>
> http://community.qnx.com/sf/go/post45365
Christian Damus wrote:
> Hi, Keith,
> can just add
The headers are not found because by default qcc uses the Dinkumware C++
library which does not have tr1 support. If you switch the C++ library
variant to GNU libstdc++ (qcc's -Y_gpp option) then qcc will add the
include path to $(QNX_TARGET)/usr/include/c++/4.3.3/<canonical name>.
Specifying the -Y_gpp option will link the binary against libstdc++
instead of libcpp.
The way to use the GNU libstdc++-v3 in the IDE is to go to the Linker
tab and select in the "Link against CPP Library" select "GNU with
Exceptions".
Ryan Mansfield
>> Thanks.
>> Test Program:
>> #include <cstdlib>
>> #include <iostream>
>> General
> http://community.qnx.com/sf/go/post45407
Oo!  Thanks, Ryan.
Definitely a superior answer.  :-)
cW
> > Hi, Keith,
> > can just add
> instead of libcpp.
> Exceptions".
> Regards,
> Ryan Mansfield
--------8<--------
Thanks. That fixed my tr1 problem.
