Forum Topic - finding memory leaks with librcheck or libmalloc: (6 Items)
I'm trying to find some memory leak on a running program on my target.
I've seen the subject wiki3513, but when I set the following environment variable:
export LD_PRELOAD=librcheck.so.1
and run my program, I'v the error message :
# unknown symbol: pthread_setname_np
unknown symbol: __ldd_deregister_eh
unknown symbol: __ldd_register_eh
Could not resolve all symbols
How can I fix that?
Is it possible to do the same thing with the libmalloc?
With the libmalloc tool I get a dump file (using MALLOC_DUMP_LEAKS=/tmp/leak_mem), but I miss the allocation backtrace.
Maÿlis
Re: finding memory leaks with librcheck or libmalloc
These errors indicate that you running it on QNX 6.3.0, this library can run only on 6.3.2.
For 6.3.0 use libmalloc_g.so.2 (or libmalloc.so.2 located in debug folder on target, I don't remember full path...)
It's /usr/lib/libmalloc_g.so, it's actually a link to
the /usr/lib/malloc_g/libmalloc.so.2
Reply-to: post43678@community.qnx.com
To: general-ide <post43678@community.qnx.com>
Subject: Re: finding memory leaks with librcheck or libmalloc
Date: Fri, 11 Dec 2009 12:21:45 -0500 (EST)
Like I've said, I tried with the debug libmalloc. I succed to have a memory leak dump file (using export
MALLOC_DUMP_LEAKS=/logfile)
I found which pointer was not desallocated but I need to know where this allocation was made.
I've tried to connect to my target from the IDE (created a null project with the binary and launching a remote profile
session via QCONN  in order to see the allocation backtrace), but I don't see anything in the IDE not even the
allocation statistic. The console window is also empty.
The environment variables on my target are
export LD_PRELOAD=/malloc_g/libmalloc.so.2
export MALLOC_CTHREAD=1
export MALLOC_TRACE=/dev/dbgmem
Did I miss something?
thanks
Depends what you trying to do. If you want to import postmortem you need to
import both files in IDE
export MALLOC_TRACE=/logfile1
export MALLOC_DUMP_LEAKS=/logfile2
transfer both logfile1 and logfile2 to target
Using Mememory Analysis import action import both files in the same session,
trace file first, than leaks.
Btw your leak log should contain allocation backtrace, can you attach it or part of it?
