Forum Topic - Autobuild for individual QNX C projects : (7 Items)
I am trying to enable "Build on resource save" for a QNX C project as per the docs at http://www.qnx.com/developers/docs
/6.4.1/ide_en/user_guide/devel.html#BUILD in an WinnXP QNX6.4.1 IDE.
However, when I then go on to edit and save the source file, no rebuild occurs.
Am I missing something?
Cheers,
Garry
RE: Autobuild for individual QNX C projects
Did you enable the "Build Automatically" on the "General -> Workspace" preference?
From: Garry Bleasdale [mailto:community-noreply@qnx.com]
Sent: Fri 11/12/2009 5:56 AM
To: general-ide
Subject: Autobuild for individual QNX C projects
Cheers,
Garry
Attachment: Text winmail.dat 2.67 KB
Re: RE: Autobuild for individual QNX C projects
Yes I tried that - but it rebuilds the whole workspace, not just the project I am working with.
The docs suggest that by selecting build on resource save in the properties of a single project then it should work for
just that project.
Cheers,
Garry
Is the project in which you are changing the source depends on other
projects? This can happen if the project dependency causes the build on
other projects.
Reply-to: post43619@community.qnx.com
To: general-ide <post43619@community.qnx.com>
Subject: Re: RE: Autobuild for individual QNX C projects
Date: Fri, 11 Dec 2009 08:29:59 -0500 (EST)
just that project.
Cheers,
Garry
The project has no references, it is just a new hello world project.
My workspace has System Builder projects in it, with the global workpsace auto build preference set these get rebuilt
each time  change my hello world project.
Cheers,
Garry
You are right. System Build project is an exception. It does not use the
"cbuilder" spec as other C/C++ project do hance it does not have the
granularity of project level build control. Instead it uses its own
build spec which extends the Eclipse workspace resource builder thus
controlled by the global workspace preference (Build Automatically).
If you don't want System Builder projects to participate in the build,
you have to close them.
Reply-to: post43632@community.qnx.com
To: general-ide <post43632@community.qnx.com>
Date: Fri, 11 Dec 2009 09:24:40 -0500 (EST)
Cheers,
Garry
Ah, I understand now.
Just to be clear, the global workspace auto build  preference AND individual project build on resource save flags need
to be set.
Thanks very much for your help Andy.
Cheers,
Garry
