Can't debug 6.3.0sp3 target with IDE 4.6
12/09/2009 10:27 AM
post43423
Hi all,
I always worked with Momentics 6.3.0sp3, and all our targets use this version. I recently installed IDE 4.6, in order to
benefit from the upgrades to Eclipse (much better stability, code completion, etc). I therefore use the older toolchain
(Window-preferences-select install-6.3.0 SP3). I was pretty happy with the transition: builds work well, QConn works
(even though it complains about target QConns being out of date), and I can run builds on target.
However, I can't debug. When launching a debug, I get:
Error
Cannot locate 'pdebug' binary on the target (default /usr/bin/pdebug):
Target <192.168.128.183:8000> reported an error: No such file or directory
However, this file is present on the target, and debugging with the older IDE works fine.
Any ideas?
Many thanks.
