Forum Topic - 4.6, SUSE Linux 11.2 : Unable to start IDE: (12 Items)
IDE doesn`t start because required bundle (com.qnx.tools.ide.phab.core) is missing.
Steps to reproduce :
1. Install QNX SDP (Used http://www.qnx.com/download/download/19606/qnxsdp-6.4.1-200905201802-linux.bin)
2. Use /opt/qnx641/run_qde.sh script to start IDE
3. Set workspace folder
4. Wait for the workbench to load. After startup window disappears, an empty window get displayed.
After looking to <workspace>/.metadata/.log file, I`ve found that some bundles were not resolved
("Missing required bundle com.qnx.tools.ide.phab.core_0.0.0")
I tried to fix my installation by reinstalling QNX SDP, but that didn`t help.
Also, I`ve tried to launch IDE as root with no success.
Thank you
Attachment: Text .log 184.33 KB
RE: 4.6, SUSE Linux 11.2 : Unable to start IDE
The message about missing phab bundle is not a problem. Phab is only enabled for Windows host; it's disabled on Linux
host.
Your problem is the infamous Mozilla connector issue with Eclipse Ganymede running on newer Linux distributions. The
connector in Eclipse SWT package fails to start.
Please make sure you have a working XUL Runner package in your Suse 11.2 system. It should be 1.9.1 or newer. Then add
the following line to the "qde.ini" file:
-Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib/xulrunner-1.9.1/xulrunner
Change the "1.9.1" to the version of your xulrunner.
Andy
From: Konstantin x [mailto:community-noreply@qnx.com]
Sent: Sat 05/12/2009 3:35 PM
To: general-ide
Subject: 4.6, SUSE Linux 11.2 : Unable to start IDE
Thank you
General
http://community.qnx.com/sf/go/post43259
Attachment: Text winmail.dat 3.36 KB
Re: RE: 4.6, SUSE Linux 11.2 : Unable to start IDE
My problem is solved, thank you!
Konstantin
Re: 4.6, SUSE Linux 11.2 : Unable to start IDE
I am facing same issue, the only difference is the OS ie., Redhat Linux 5 version.
I have tried as suggested above.
 add the following line to the "qde.ini" file:
still the behavior is same.
Suggest me to resolve this issue.
Harish.
Did you install xulrunner?
On 13/08/10 11:21 AM, harish kumar wrote:
> Regards,
> Harish.
> http://community.qnx.com/sf/go/post62953
I have checked in the "/usr/lib" , could found xulrunner-1.9pre
then I  changed in the path as below.
-Dorg.eclipse.swt.browser.XULRunnerPath=/usr/lib/xulrunner-1.9pre/xulrunner
Harish.
And? Did it work/not work?
> Regards,
> Harish.
> http://community.qnx.com/sf/go/post63013
It did not worked.
Harish
Did you try to update your xulrunner package?
On 16/08/10 11:54 AM, harish kumar wrote:
> It did not worked.
> Regards,
> Harish
> http://community.qnx.com/sf/go/post63102
which version of  xulrunner will recommend to upgrade??
Harish
Did you read this thread???
Thanks Elena,
Its working.
Harish.
