Forum Topic - Build Woes: (5 Items)
Build Woes
I'm cleaning a project (does this during build as well) and this is what I get:
C:\QNX632\host\win32\x86\usr\bin\make clean --file=C:/DOCUME~1/Kevin/LOCALS~1/Temp/QMakefile125901260707858498.tmp
C:/QNX632/host/win32/x86/usr/bin/make -j 1 -Cnto -fMakefile clean
make[1]: Entering directory `C:/ARI_II/some_company/Code/changes/login/nto'
C:/QNX632/host/win32/x86/usr/bin/make -j 1 -Cppc -fMakefile clean
make[2]: Entering directory `C:/ARI_II/some_company/Code/changes/login/nto/ppc'
C:/QNX632/host/win32/x86/usr/bin/make -j 1 -Ca.be -fMakefile clean
make[3]: Entering directory `C:/ARI_II/some_company/Code/changes/login/nto/ppc/a.be'
C:/QNX632/host/win32/x86/usr/bin/rm -f  liblogin.a  *.pinfo *.o *.err *.map mapfile *.sym *.i
make[3]: Leaving directory `C:/ARI_II/some_company/Code/changes/login/nto/ppc/a.be'
C:/QNX632/host/win32/x86/usr/bin/make -j 1 -Ca.be.g -fMakefile clean
make[3]: Entering directory `C:/ARI_II/some_company/Code/changes/login/nto/ppc/a.be.g'
C:/QNX632/host/win32/x86/usr/bin/rm -f  liblogin_g.a  *.pinfo *.o *.err *.map mapfile *.sym *.i
make[3]: Leaving directory `C:/ARI_II/some_company/Code/changes/login/nto/ppc/a.be.g'
make[2]: Leaving directory `C:/ARI_II/some_company/Code/changes/login/nto/ppc'
C:/QNX632/host/win32/x86/usr/bin/make -j 1 -Cx86 -fMakefile clean
make[2]: Entering directory `C:/ARI_II/some_company/Code/changes/login/nto/x86'
C:/QNX632/host/win32/x86/usr/bin/make -j 1 -Ca -fMakefile clean
make[3]: Entering directory `C:/ARI_II/some_company/Code/changes/login/nto/x86/a'
make[3]: Leaving directory `C:/ARI_II/some_company/Code/changes/login/nto/x86/a'
C:/QNX632/host/win32/x86/usr/bin/make -j 1 -Ca.g -fMakefile clean
Makefile:1: ../../../common.mk
: Invalid argument
make[3]: Entering directory `C:/ARI_II/some_company/Code/changes/login/nto/x86/a.g'
make[3]: *** No rule to make target `../../../common.mk
make[3]: Leaving directory `C:/ARI_II/some_company/Code/changes/login/nto/x86/a.g'
'.  Stop.
make[2]: Leaving directory `C:/ARI_II/some_company/Code/changes/login/nto/x86'
make[2]: *** [clean] Error 2
make[1]: *** [clean] Error 2
make[1]: Leaving directory `C:/ARI_II/some_company/Code/changes/login/nto'
C:\QNX632\host\win32\x86\usr\bin\make: *** [clean] Error 2
My difficulty is in the fact that the "changes/login/nto/x86/a" worked fine but the "changes/login/nto/x86/a.g" won't.
The make files in the a and a.g are identical.
Why this all of a sudden?
Kevin
Re: Build Woes
They aren't identical, I was hit with the invisible killer....windows end of line delimiters....the misery a checkbox
can cause....
Fixed.
Kevin
Re: Build Woes
That raises a pet peeve of mine - programmer's editors that try to hide the fact that a file does not have native
linefeed markers...
Just the facts, man! B-)
can cause....
> Fixed.
> Kevin
> http://community.qnx.com/sf/go/post42447
cburgess@qnx.com
Re: Build Woes
Hi, Colin, Kevin,
FYI:  The IDE has a handy menu action to resolve such problems:  "File
-> Convert Line Delimiters To."
Of course, you still need to discover that you have this problem, in the
first place.
cW
linefeed markers...
checkbox can cause....
> > Fixed.
> > Kevin
> > General
________________________________________________________________________
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems
Re: Build Woes
Yes, that's my peeve.  I can simply use textto, tr, or even the IDE(!)
to convert, but when the editor silently hides the issue, it can lead
to things like make getting upset.
vim does it, but at least it marks it as "[dos]" at the bottom of the
screen...
Christian Damus wrote:
> Hi, Colin, Kevin,
> first place.
> cW
linefeed markers...
>>> Fixed.
>>> Kevin
>>> General
> Christian W. Damus
> http://community.qnx.com/sf/go/post42466
cburgess@qnx.com
