Forum Topic - C++ Make project - 'RM := del' in makefile: (3 Items)
QNX 6.4.1 IDE 4.6 Windows host
Customer reported, and I reproduced that if you follow the IDE doc instructions for 'Creating the equivalent of a make
project' and set the 'Generate Makefiles automatically' option like it says, the resulting makefile starts:
# Automatically-generated file. Do not edit!
-include ../makefile.init
RM := del
[snip]
If you run a 'make clean', it fails to find 'del' :
**** Clean-only build of configuration QNX QCC for project testmake ****
make clean
del  ./testmake.d  testmake
process_begin: CreateProcess(NULL, del ./testmake.d testmake, ...) failed.
make (e=2): The system cannot find the file specified.
make: [clean] Error 2 (ignored)
Known issue ? Any workaround ?
Dave
Re: C++ Make project - 'RM := del' in makefile
That's bizarre.  I can reproduce this, too.
If you just create a managed-make project to begin with, then you get
the correct result (which is "RM := rm -rf").  It is simpler to start
with a managed project (e.g., the "Empty Project" or "Hello World ANSI C
Project" template in the "Executable" category of the wizard) and just
change the builder to "Gnu Make Builder" from "CDT Internal Builder."
That requires fewer steps and produces the correct result.
As for why the other procedure results in "del" being used as the RM
command, I suspect that the change from non-managed to managed build
didn't pick up the QCC toolchain's specification of the default RM
command, because the project "remembers" a different default.  Feel free
to raise an IDE PR for that.
Cheers,
Christian
> RM := del
> [snip]
> make clean
> Thanks
> Dave
> http://community.qnx.com/sf/go/post41248
________________________________________________________________________
Christian W. Damus
Software Developer, IDE Team
QNX Software Systems
Thanks Christian - PR72476 tracks this.
Cheers
Dave
> Cheers,
> Christian
> instructions for 'Creating the equivalent of a make project' and set
> > RM := del
> > [snip]
> > make clean
> failed.
> > Thanks
> > Dave
> > General
> Christian W. Damus
> http://community.qnx.com/sf/go/post41265
Dave Bott (dbott@qnx.com)	Field Applications Engineer
QNX Software Systems, Inc.	Cell:408 391-3535
San Jose CA
Join Foundry27 <http://community.qnx.com>;  - the new QNX developer forum.
