Re: failed to start IDE 4.6
10/15/2009 12:05 PM
post40052
It does specify which OS you are using (Linux), but not your distribution.
ArchLinux isn't a support platform. It seems that your problem is the version of the XULRunner library in your
distribution. IDE 4.6 only supports XULRunner 1.8.x - 1.9.0.x.
You can either update the library to one of those versions, or you can download a matching XULRunner version, extract it
and have IDE use that specific version. To do so modify the "qde.ini" file under $QNX_HOST/usr/qde/eclipse directory,
add the following line to the file:
-Dorg.eclipse.swt.browser.XULRunnerPath=/PATH_TO_YOUR_XUL_RUNNER
> ArchLinux + QNX6.4.1.
> It is not in the log?
