Re: 6.4.0 / 6.4.1 / msys core 1.0.10 vs 1.0.11 make problems
10/06/2009 3:01 PM
post39452
Are you using make that comes with msys?
If so, please don't. Use our make.exe, and replace only msys
dll and rm/ls.
See if that works.
There are known issues with our make.exe that we shipped
with 6.4.0/6.4.1 (MAKEFLAGS, UNC paths); if you are
epxeriencing such problems, could you download this
experimental version from here:
http://community.qnx.com/sf/go/post39262
Hope this helps,
Aleksandar
David Thompson wrote:
> topic9517: Slow rm / ls performance using 6.4.0 toolchain is loosely related.
> While investigating topic9517 I discovered msysCORE-1.0.11 greatly improved
> build performance on 6.4.0 and 6.4.1 when connected to a network.
> However, there are build errors when using msys1.0.11 that I need to fix.
> An app that builds with 6.4.1/msys1.0.10 will not build with 6.4.1/msys1.0.11.
> Looking at the output of a make -p (write to standard output the complete set
> of macro definitions and target descriptions) shows some (not all) differences:
> with msys1.0.10
> PRODUCT_ROOT := d:/emb/qnx630/baseline/apps/src/jenser/iopkt
> common := d:/emb/qnx630/baseline/apps/src/jenser/iopkt/jenser/common.mk
> CPU_ROOT := d:/emb/qnx630/baseline/apps/src/jenser/iopkt/jenser/ppc
> with msys1.0.11
> PRODUCT_ROOT := /d/emb/qnx630/baseline/apps/src/jenser/iopkt
> common := /d/emb/qnx630/baseline/apps/src/jenser/iopkt/jenser/common.mk
> CPU_ROOT := /d/emb/qnx630/baseline/apps/src/jenser/iopkt/jenser/ppc
> More importantly I think the INCVPATH variables also show the missing ":" in
> the drive letter portion with msys1.0.11. All the -I parameters reflect this.
> With all other things being identical,
> msys1.0.11 gives this error that msys1.0.10 does not:
> make[3]: *** No rule to make target `libdrvrS.a', needed by `/d/emb/qnx630/basel
> ine/apps/src/jenser/iopkt/jenser/ppc/dll-be/devnp-jenser.so'. Stop.
> I noticed that $(QNX_TARGET)/usr/include/mk/qmacros.mk has changed.
> Is there a simple fix to restore the ":" to the drive letter and perhaps fix my
> broken build?
> Anyone at QNX willing to try to duplicate the msys1.0.11 build error on your apps?
> I can not live with the poor network performance on msys1.0.10 but having a broken
> build with msys1.0.11 is no better.
> http://community.qnx.com/sf/go/post39451
