Forum Topic - Rhapsody, QNX, and Photon Application Builder:
Hello All,
I am using IBM/Telelogic Rhapsody (v 7.5) together with QNX (v 6.4.1) for a development of a new application. The
application will have a GUI which I would like to create with the Photon Application Builder. Does anyone have
experience developing applications with Rhapsody and PhAB? What is the recommended way to communicate between the two
processes? The User of the application should be able to enter information via the GUI as well as see run time control
data on the GUI. Or is it recommended to program the GUI without the PhAB and to call the Photon library functions
directly from the Rhapsody Model/code? It would be nice to have a solution using the PhAB since it greatly simplifies
the creation of Windows and their layout.
Thank you for you help
Cheers
Marcel
RE: Rhapsody, QNX, and Photon Application Builder
Hi Marcel,
Would the Rhapsody be a separate process?  You could just use IPC
between the processes, sending messages for control back-and-forth.  You
can program your GUI layout using phab, the use a Photon API called
PtAppAddInput() and/or PtAppAddFd() if you wish to use 'fd' based
communication.
Kind Regards,
-Derek
From: Marcel Meerstetter [mailto:community-noreply@qnx.com]
Sent: Thursday, August 13, 2009 9:48 AM
To: photon-graphics
Subject: Rhapsody, QNX, and Photon Application Builder
Hello All,
for a development of a new application. The application will have a GUI
anyone have experience developing applications with Rhapsody and PhAB?
What is the recommended way to communicate between the two processes?
GUI as well as see run time control data on the GUI. Or is it
library functions directly from the Rhapsody Model/code? It would be
nice to have a solution using the PhAB since it greatly simplifies the
Cheers
Marcel
Photon microGUI
http://community.qnx.com/sf/go/post35909
Re: RE: Rhapsody, QNX, and Photon Application Builder
Hello Derek,
The way I understand it is that if I were to use the PhAB, there would have to be two Processes, since PhAB creates its
own process and Rhapsody would too. I will look into your recommendation of using the API functions called
PtAppAddInput() and PtAppAddFd().
Thanks for the help,
Marcel
RE: RE: Rhapsody, QNX, and Photon Application Builder
Hi Marcel,
With the PhAB, or Photon in general, it is possible to put everything in
one process, I just think it will be cleaner, and easier to maintain if
both are in separate processes.  The only time I would consider one
process is if the IPC was causing too much overhead, but even then, it
could be a problem of the designed system.  One advantage of separate
processes, is if the GUI goes down, the control process can keep
running, and vice versa.
If you need any more ideas, do not hesitate to ask.
Kind Regards,
-Derek
Sent: Thursday, August 13, 2009 11:17 AM
To: photon-graphics
Subject: Re: RE: Rhapsody, QNX, and Photon Application Builder
Hello Derek,
have to be two Processes, since PhAB creates its own process and
API functions called PtAppAddInput() and PtAppAddFd().
Marcel
Photon microGUI
http://community.qnx.com/sf/go/post35919
