Forum Topic - PdCreateOffscreenContextGF() questions:
Documentation ( http://www.qnx.com/developers/docs/6.4.1/photon/lib_ref/pd/pdcreateoffscreencontextgf.html ) says:
"If there isn't enough space in video RAM to create the offscreen context, the behavior of this function depends on the
driver; most drivers allocate space in system memory instead (if none of SYS_ONLY, 2D_WRITABLE, or 2D_READABLE are set
in flags)."
Is it true ? Does this function creates a clone of GF surface in memory ? Or it just binds GF surface for usage by
Photon API without any video memory allocation, as mentioned in the documentation before this quotation ?
What will be If I call PhDCRelease() for offscreen context created by PdCreateOffscreenContextGF() function ? As far as
I understand it must destroy PdOffscreenContext_t structure (handle), but GF surface will not be destroyed, is it right
Re: PdCreateOffscreenContextGF() questions
>  behavior of this function depends on the driver; most drivers allocate space
>  set in flags)."
> it just binds GF surface for usage by Photon API without any video memory
> PdCreateOffscreenContextGF() function ? As far as I understand it must destroy
> , is it right ?
It is early in the morning, but I think I understand the code ... io-graphics will call gf_surface_free(), but io-
display will not release the surface unless the reference count has been reduced to 1, so there should be no issue.
Kind Regards,
-Derek
And yes, to attached to the surface, it call gf_surface_attach_by_sid() ...
