Forum Topic - how to catch ptwindow arm event:
Hi:
My application has an empty ptWindow, (there is no any widget inside). I can not catch the arm and disarm event! (But I
can catch the window openning event).  please help me to get click and double click event on this ptwindow. thanks
weixing
Re: how to catch ptwindow arm event
I assume you attached Pt_CB_ARM and Pt_CB_DISARM callbacks to your window already ;-)
You need to make sure that the Pt_ARG_FLAGS of your window has Pt_SELECTABLE set.
Ok, I can catch the event now. thanks.
Another simple question: in the add callback function window, we can select Code Types [Code, Done, Cancel], Can I know
which API function is same as Done ? I need to call it in my C source to close window.
