Forum Topic - Shelf show/hide in application:
Hi:
By command:shelf -e, we can click [Shelf is Open] to hide.
My application need to hide/show Shelf (both at bottom and right), so that my Ptwindow can be fullscreen.
how can I hide/show the Shelf in my C program ?
Weixing
Re: Shelf show/hide in application
Currently there is no way of doing it via an API.
But you can try to do something like this:
- setup your shelfs to auto-collapse
- use PhMoveCursorAbs() to move the pointer over a shelf when needed -- this will make shelf auto-expand, once you move
cursor away from the shelf it will auto-collapse.
But when you run calib command, it will hide the shelf. and it goes to fullscreen. quit the calib, the shelf will come
again.
I want to do same as calib, Can I know how the calib do it ?
Ok. Disable all decorations on your window (Pt_ARG_WINDOW_RENDER_FLAGS) and set the dim of your window to occupy the
entire screen (Pt_ARG_DIM).
You could use spawn to start shelf -e from your app.
- Malte
