Forum Topic - Handling Ph_WM_RESIZE in 6.4.1 (6.4.0):
The window has been initialized using these flags:
   PtSetArg(&winargs[winargc++], Pt_ARG_WINDOW_MANAGED_FLAGS, Pt_FALSE, Ph_WM_APP_DEF_MANAGED);
   PtSetArg(&winargs[winargc++], Pt_ARG_WINDOW_MANAGED_FLAGS, Pt_TRUE, Ph_WM_BACKDROP | Ph_WM_TOFRONT | Ph_WM_COLLAPSE |
 Ph_WM_FFRONT | Ph_WM_FOCUS | Ph_WM_HELP | Ph_WM_HIDE | Ph_WM_MAX | Ph_WM_MENU | Ph_WM_MOVE | Ph_WM_RESIZE |
Ph_WM_RESTORE | Ph_WM_TASKBAR | Ph_WM_TOBACK);
   PtSetArg(&winargs[winargc++], Pt_ARG_WINDOW_NOTIFY_FLAGS, Pt_FALSE, Ph_WM_RESIZE | Ph_WM_CLOSE | Ph_WM_HELP);
   PtSetArg(&winargs[winargc++], Pt_ARG_WINDOW_NOTIFY_FLAGS, Pt_TRUE, Ph_WM_CLOSE | Ph_WM_COLLAPSE | Ph_WM_FOCUS |
Ph_WM_MAX | Ph_WM_MOVE  | Ph_WM_RESIZE | Ph_WM_RESTORE | Ph_WM_HIDE);
I can't catch Ph_WM_RESIZE event with these parameters because this event is not emitted after window resize.
When Ph_WM_RESIZE is removed from Pt_ARG_WINDOW_MANAGED_FLAGS flags, the Ph_WM_RESIZE is emitted, but as far as I can
know I need manually resize window and change its position if resize event is not managed by WM.
Pt_ARG_POS resource can be changed without any problem, window changes its position, but Pt_ARG_DIM resource settings
are ignored by PtWindow widget. In 6.3.2 behavior was different.
My thoughts was about maximum/minimum widget dimension setting problem, by I set:
   winsize.w=0;
   winsize.h=0;
   PtSetArg(&winargs[winargc++], Pt_ARG_MAX_HEIGHT, 0, 0);
   PtSetArg(&winargs[winargc++], Pt_ARG_MAX_WIDTH, 0, 0);
   PtSetArg(&winargs[winargc++], Pt_ARG_MIN_HEIGHT, 0, 0);
   PtSetArg(&winargs[winargc++], Pt_ARG_MIN_WIDTH, 0, 0);
   PtSetArg(&winargs[winargc++], Pt_ARG_MAXIMUM_DIM, &winsize, 0);
   PtSetArg(&winargs[winargc++], Pt_ARG_MINIMUM_DIM, &winsize, 0);
This doesn't helps me to resize window widget. And later:
   winsize.w=65536;
   winsize.h=65536;
   winsize.w=0;
   winsize.h=0;
This doesn't work too.
What am I missed ?
P.S. Documentation doesn't have nothing about Pt_ARG_MINIMUM_DIM/Pt_ARG_MAXIMUM_DIM default value 0,0 behavior. What  0,
0 does ? Is it the same as in the Pt_ARG_MAX_WIDTH/Pt_ARG_MAX_HEIGHT ?
RE: Handling Ph_WM_RESIZE in 6.4.1 (6.4.0)
What about the Pt_CB_RESIZE callback?  Does this work at all?
From: Mike Gorchak [mailto:community-noreply@qnx.com]
Sent: Wed 29/04/2009 10:25 AM
To: photon-graphics
Subject: Handling Ph_WM_RESIZE in 6.4.1 (6.4.0)
   winsize.w=0;
   winsize.h=0;
   winsize.w=65536;
   winsize.h=65536;
   winsize.w=0;
   winsize.h=0;
What am I missed ?
Photon microGUI
http://community.qnx.com/sf/go/post28351
Attachment: Text winmail.dat 4.83 KB
Re: RE: Handling Ph_WM_RESIZE in 6.4.1 (6.4.0)
I'm not using callback, I use PhPeekEvent to collect window events. So I can't say works this callback or not ...
Re: Handling Ph_WM_RESIZE in 6.4.1 (6.4.0)
About width/height vs. dim, they are the same ...
case Pt_ARG_MAX_HEIGHT:
   1003 			if( window->max_height == (short)arg->value )
   1004 				break;
   1005 			widget->max_dim.h = window->max_height = max((short)arg->value, ((short)arg->value > 0 ) ? window->min_height
 : SHRT_MAX );
   1006 			if (widget->area.size.h > widget->max_dim.h ) {
   1007 				widget->area.size.h = widget->max_dim.h;
   1008 				widget->flags |= Pt_WIDGET_RESIZE;
   1009 				PtInvalidateCanvas(widget);
   1010 				}
   1011 			PtWindowSetInfo( Ph_WM_SET_FRAME_ATTRIB, widget );
   1012 			break;
   1013 		case Pt_ARG_MAX_WIDTH:
   1014 			if( window->max_width == (short)arg->value )
   1015 				break;
   1016 			widget->max_dim.w = window->max_width = max((short)arg->value, ((short)arg->value > 0 ) ? window->min_width :
 SHRT_MAX );
   1017 			if (widget->area.size.w > widget->max_dim.w ) {
   1018 				widget->area.size.w = widget->max_dim.w;
   1019 				widget->flags |= Pt_WIDGET_RESIZE;
   1020 				PtInvalidateCanvas(widget);
   1021 				}
   1022 			PtWindowSetInfo( Ph_WM_SET_FRAME_ATTRIB, widget );
   1023 			break;
are you trying to write your own main loop?
Yes, it is not a complex task, except resize issues in 6.4.x.
I am not sure, but I think it was a "bug" in 632, it was processing events even though they were not "managed", I am not
 sure how to force pwm to redraw/resize the window ... what happens if you:
received the Ph_WM_RESIZE:
enqueue a "resize" message for processing outside your main loop.
when messages are done, then:
flip on the managed bit, and damage the window
Hopefully some other Photon guys can clarify ... :)
-Derek
Sent: Thu 30/04/2009 8:24 AM
To: photon-graphics
Subject: Re: Handling Ph_WM_RESIZE in 6.4.1 (6.4.0)
Photon microGUI
http://community.qnx.com/sf/go/post28429
Attachment: Text winmail.dat 4.14 KB
Mike, could you post your sample app, so I can quickly try it on my end?
Ok. It is SDL 1.3, I'll commit all necessary changes to SVN this weekend and you can checkout it using "svn checkout
http://svn.libsdl.org/trunk/SDL" . I'll post a message here when all my changes will be in SVN.
I would like to get a small sample that demostrates just this problem.
Ok, this is an example.
Attachment: Text phresize.tar.gz 5.53 KB
The bug is in the sample code. The code uses the winsize dim for these resources:
Pt_ARG_MAXIMUM_DIM, Pt_ARG_MINIMUM_DIM and Pt_ARG_DIM.
By the time the PtCreateWidget() is called the winsize is set to 640x480, so all of these resources will be tried to be
set to 640x480. When trying to resize the window, the size is constrained to 640x480 as expected.
> resources:
> all of these resources will be tried to be set to 640x480. When trying to
Thanks for the help. Stupid bug .... :-/
