Forum Topic - create and delete widget:
hello everyone,
I am new in GUI, how to create and delete widget using script ?
thank you.
best regards
afif
Re: create and delete widget
Hi Afif,
Please specify what do you mean by script: shell script or program code?
There are two basic ways to create a widget: using Photon Application Builder (PhAB) or  using c/c++ code in your
program.
For PhAB see:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.photon_prog_guide%2Fwidgets.html&cp=17_0_6
For code see:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.photon_prog_guide%2Fwgt_code.html&cp=17_0_12
Best regards,
Fedor
I don't understand how to use the code, I want to create an image as label and the picture is in my directory.
You can use PxLoadImage() and then PtSetResource() with Pt_ARG_LABEL_IMAGE flag.
E.g.
PhImage_t *my_image;
my_image = PxLoadImage(“/home/my_pict.jpg”, NULL);
PtSetResource( ABW_my_label, Pt_ARG_LABEL_IMAGE, my_image, 0 );
For more information please read following help topics about PtLabel and PhImage_t:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.photon_widget_ref%2Fptlabel.html&cp=17_2_2_32
and
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.photon_lib_ref%2Fph%2Fphimage_t.html&cp=
17_1_9_55 .
Best regards,
Fedor
my script is like this :
 my_image= PxLoadImage("/home/PSR.jpg",NULL);
 my_label=PtCreateWidget(PtLabel,Pt_NO_PARENT,1,args);
but it's error because my_label is not define. what should I do?
Thank you.
and I get error Pxloadimage is undefined.
does anyone know the reason?
thank you
Hi Afif,
> Thank you.
PtLabbel requires parent widget.
For more information please read:
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.photon_prog_guide%2Fnonphab.html&cp=17_0_27
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.photon_lib_ref%2Fpt%2Fptcreatewidget.html&cp=17_1_13_101
http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=%2Fcom.qnx.doc.photon_lib_ref%2Fpt%2Fptsetparentwidget.html&cp=17_1_13_228
> and I get
> thank you
You have to include phexlib library in your common.mk.
E.g.
LIBS += phexlib
Best regards,
Fedor
