Forum Topic - System hanging with devi-hid on i7 smp - QNX 6.5:
Have you experienced problems with iNTEL i7 / Q77 devi-hid driver in SMP configuration.
If we start ph utility, system hangs  at "Waiting for input driver"  displaying login windows.
If we start photon manually (actually : io-display, io-graphics, pwm, bkgdmgr , etc) all works fine until we try to
start "devi-hid mouse". At this time the system hangs.
If we don't start the SMP kernel, we don't have this kind of problem (ph starts without any problem)
Any idea ?
Re: System hanging with devi-hid on i7 smp - QNX 6.5
Hi Philippe,
To boot with SMP kernel you have to build boot image in which io-hid and devc-con-hid both launch on the same CPU core.
To do this you should use on -C0, for example:
on -C0 /proc/boot/io-hid -dusb /dev/io-usb/io-usb
waitfor /dev/io-hid/io-hid
on -C0 /proc/boot/devc-con-hid -n5 &
reopen /dev/con1
Let me know how it works on your configuration.
28 мая 2015 г., в 11:52:30, Philippe Elskens <community-noreply@qnx.com> написал:
> Hello,
> Any idea ?
> Photon microGUI
> http://community.qnx.com/sf/go/post113868
> To cancel your subscription to this discussion, please e-mail photon-graphics-unsubscribe@community.qnx.com
Hi Oleg
On our application we are using touch screen and mouse. These devices are connected on usb.
At boot time my system starts :
    io-hid -d ps2ser kbd:kbddev:ps2mouse:mousedev -d usb /dev/io-usb/io-usb
    and if later I start  "devi-hid mouse touch" .... the system hang
But now if I slay the driver io-hid and restart it  (in rc.local for instance)  with the following  command:
io-hid  -d usb /dev/io-usb/io-usb
I can start "devi-hid mouse touch" and it works fine.
I'll also try your suggestion
