Forum Topic - Can't start Phab:
Can't start Phab
Phab could start normally before. But now it does not work. I have not change any configuration.
When I click start Phab button, Console for PhAB prints:
"[7424]
phfont: init...
phfont:initialized.
phfont:'tcp:127.0.0.1:4870[<32|64>]' server installed.
Starting Photon server...
[2492]
Starting Phindows...
[3964]
Starting Window Manager...
[4244]
Running appbuilder.exe...
[6620]
PhAB exited abnormally. Photon will not be shut down.
[6620] appbuilder.exe exited (0)
The project can open PhAB on another PC normally.
I have reinstalled the IDE many times. The problem still exists.
Re: Can't start Phab
Please describe your problem step by step.
How do you connect to your target system?
Which version of the IDE and QNX are you using?
I'll try to reproduce your problem...
Regards, Gleb.
I can open phab on momentics IDE with the same project several months ago. And I do not execute any special step.
I just select the project, click phab on the IDE. Then PhAB crashes.
The version of QNX Momentics IDE is 4.6 and QNX version is 6.4.1
