Forum Topic - ApSetTranslation() ignores language regionalization:
Hi folks,
I have a Photon GUI running QNX OS 6.4.1. I use the QNX Translation mechanism for different languages.
During application initialization I use this command to initialize the language of my GUI:
int res = ApSetTranslation("de_DE")     // for German language in Germany.
This returns 0 for success and loads the language file from the set path of ABLPATH=/usr/photon/translations which
results in the file path of:
ABLPATH=/usr/photon/translations/myapplication.de_DE
This mechanism works fine with several languages, as long as I don't seperate between regional versions of one language.
 As soon as I try to seperate between "de_DE" and "de_CH" I always get the return value "0" for success, but the
language file "de_DE" is always loaded.
Example: I have the language files: "myapplication.de_DE" and "myapplication.de_CH". In this case with ApSetTranslation(
"de_CH") still the "de_DE" language file is loaded.
But if I delete the "de_DE" file from harddrive, the application loads "de_CH" instead. The same behaviour was verified
using "fr_FR" and "fr_CA".
I assume there must be something going wrong with the best  match algorithm described here in the documentation,
unfortunately I can't find out what.
http://www.qnx.com/developers/docs/6.3.2/photon/prog_guide/languages.html#RunningYourApplication
So if anybody has a great idea how to solve this mystery your help is really appreciated!!
Thanks and Greetings,
Martin H.
Re: ApSetTranslation() ignores language regionalization
            Hi, Martin.
I have reproduced this behavior in QNX 6.4.1. But in QNX 6.5.0 algorithm working as intended.
Alexander.
> Hi folks,
> language of my GUI:
> ABLPATH=/usr/photon/translations which results in the file path of:
> between regional versions of one language. As soon as I try to seperate
>  the language file "de_DE" is always loaded.
> de_CH". In this case with ApSetTranslation("de_CH") still the "de_DE" language
>  file is loaded.
>  instead. The same behaviour was verified using "fr_FR" and "fr_CA".
> described here in the documentation, unfortunately I can't find out what.
> appreciated!!
> Martin H.
Hi Alex,
thanks for verifying this bug.
Greetings, Martin
