Forum Topic - PtProgress widgets has wrong border color:
I have a PtOSCOntainer widget with blue fill color. As its child I have PtMTrend widget which has black fill color by
default. On top of that (empty) trend widget, I have a PtProgress widget. The colors for Pt_ARG_PROGRESS_BAR_COLOR and
Pt_ARG_FILL_COLOR are set correctly and appear as wished, but there still is a blue border around the progress bar
widget. This blue border cannot be changed by setting Pt_ARG_BORDER_COLOR.
Which arguments do I have to set in order to either erase this wrong border or at least change its color?
Jan
Re: PtProgress widgets has wrong border color
Hi Jan,
To disable border of PtProgress widget you have to set Pt_HIGHLIGHT to Pt_FALSE.
01 июля 2014 г., в 14:58:55, Jan Körner <community-noreply@qnx.com> написал:
> Regards,
> Jan
> Photon microGUI
> http://community.qnx.com/sf/go/post110901
> To cancel your subscription to this discussion, please e-mail photon-graphics-unsubscribe@community.qnx.com
Hi Oleg,
thank you for that suggestion. Unfortunately, it does not work for me.
The Pt_HIGHLIGHTED entry of Pt_ARG_FLAGS is already set to 0 by default. Even if I reset it, the appearance does not
change.
I only can change the border by changing Pt_ARG_HIGHLIGHT_ROUNDNESS to > 0. That makes the green Pt_ARG_INLINE_COLOR
line to have round corners and the blue border is not visible anymore. Perhaps the green inline overlaps the blue border
 in this case.
Jan
Hi Jan,
What version of QNX do you use? Can you send me a minimal source to reproduce your issue?
08 июля 2014 г., в 16:43:59, Jan Körner <community-noreply@qnx.com> написал:
> Hi Oleg,
change.
 in this case.
> Regards,
> Jan
> Photon microGUI
> http://community.qnx.com/sf/go/post110972
Hi Oleg,
I use QNX 6.5.
Here are is (a part of) my code:
PtWidget_t* m_root, m_container, m_trend, m_cardio, m_progress
m_root = PtCreateWidget(PtWindow, Pt_NO_PARENT, 0, NULL);
PtSetResource(m_root, Pt_ARG_MARGIN_HEIGHT, 0, 0);
PtSetResource(m_root, Pt_ARG_MARGIN_WIDTH, 0, 0);
const PhArea_t areaRoot = {{0, 0}, {640, 480}};
PtSetResource(m_root, Pt_ARG_AREA, reinterpret_cast<long>(&areaRoot), 0);
PtRealizeWidget(m_root);
m_container = PtCreateWidget(PtOSContainer, m_root, 0, NULL);
PtSetResource(m_container, Pt_ARG_MARGIN_HEIGHT, 0, 0);
PtSetResource(m_container, Pt_ARG_MARGIN_WIDTH, 0, 0);
const PhArea_t areaCont = {{0, 0}, {640, 480}};
PtSetResource(m_container, Pt_ARG_AREA, reinterpret_cast<long>(&areaCont), 0);
PtSetResource(m_container, Pt_ARG_FILL_COLOR, Pg_BLUE, 0);
PtRealizeWidget(m_container);
m_trend= PtCreateWidget(PtLabel, m_container, 0, NULL);
PtSetResource(m_trend, Pt_ARG_MARGIN_HEIGHT, 0, 0);
PtSetResource(m_trend, Pt_ARG_MARGIN_WIDTH, 0, 0);
const PhArea_t areaTrend = {{0, 50}, {640, 200}};
PtSetResource(m_trend, Pt_ARG_AREA, reinterpret_cast<long>(&areaTrend), 0);
PtSetResource(m_trend, Pt_ARG_FILL_COLOR, Pg_BLACK, 0);
PtRealizeWidget(m_trend);
m_cardio= PtCreateWidget(PtMTrend, m_container, 0, NULL);
PtSetResource(m_cardio, Pt_ARG_MARGIN_HEIGHT, 0, 0);
PtSetResource(m_cardio, Pt_ARG_MARGIN_WIDTH, 0, 0);
const PhArea_t areaCardio = {{0, 50}, {600, 200}};
PtSetResource(m_cardio, Pt_ARG_AREA, reinterpret_cast<long>(&areaCardio), 0);
PtRealizeWidget(m_cardio);
m_progress= PtCreateWidget(PtProgress, m_container, 0, NULL);
PtSetResource(m_progress, Pt_ARG_MARGIN_HEIGHT, 0, 0);
PtSetResource(m_progress, Pt_ARG_MARGIN_WIDTH, 0, 0);
PtSetResource(m_progress, Pt_ARG_HORIZONTAL_ALIGNMENT, Pt_LEFT, 0);
PtSetResource(m_progress, Pt_ARG_VERTICAL_ALIGNMENT, Pt_TOP, 0);
PtSetResource(m_progress, Pt_ARG_PROGRESS_BAR_COLOR, Pg_GREEN, 0);
PtSetResource(m_progress, Pt_ARG_FILL_COLOR, Pg_BLACK, 0);
const PhArea_t areaProg = {{200, 100}, {200, 50}};
PtSetResource(m_progress, Pt_ARG_AREA, reinterpret_cast<long>(&areaProg ), 0);
PtRealizeWidget(m_progress);
Jan
Hi Jan,
Here is a modified source. String marked "border will be hidden" disables a border.
int main( )	{
	PtWidget_t *m_root, *m_container, *m_trend, *m_cardio, *m_progress;
	m_root = PtCreateWidget( PtWindow, Pt_NO_PARENT, 0, NULL);
	PtSetResource( m_root, Pt_ARG_MARGIN_HEIGHT, 0, 0);
	PtSetResource( m_root, Pt_ARG_MARGIN_WIDTH, 0, 0);
	PtSetResource( m_root, Pt_ARG_AREA, (long)(&areaRoot), 0);
	 PtSetResource(m_container, Pt_ARG_AREA, (long)(&areaCont), 0);
	 PtSetResource(m_trend, Pt_ARG_AREA, (long)(&areaTrend), 0);
	 PtSetResource(m_cardio, Pt_ARG_AREA, (long)(&areaCardio), 0);
	PtSetResource(m_progress, Pt_ARG_AREA, (long)(&areaProg ), 0);
	PtSetResource( m_progress, Pt_ARG_FLAGS, Pt_FALSE, Pt_HIGHLIGHTED ); // border will be hidden
	return( Pt_CONTINUE );
09 июля 2014 г., в 15:39:02, Jan Körner <community-noreply@qnx.com> написал:
> Hi Oleg,
> I use QNX 6.5.
> PtSetResource(m_cardio, Pt_ARG_MARGIN_WIDTH, 0,...
