Forum Topic - io-graphics disables output from devc-con-hid:
I am playing with an x86 system with 5 graphic outputs.
1 x Onboard graphics and
4 x pci graphics board (smi5xx)
The onboard graphics is only used as console interface (devc-con-hid).
The pci boards are used for 4 different Photon Sessions.
After starting the 1st io-graphics for one of the PCI-Boards, the console output(devc-con-hid) is no longer taking place
After slaying  io-graphics the console is back.
There is of course no Photon running for the onboard Interface.
Any idea?
-Michael
Re: io-graphics disables output from devc-con-hid
Hello, Michael!
Please attach your 'display.conf' file and the output of 'pidin ar' for the 1st Photon Session, including command-line
options of the io-graphics.
Best regards,
Andrey
Hello Andrey,
attached you will find display.conf.
Here are the info's from pidin ar :
  208927 io-graphics -dvid=0x126f,did=0x0501,deviceindex=0 -n /dev/photon0
  237603 io-graphics -dvid=0x126f,did=0x0501,deviceindex=1 -n /dev/photon1
  274469 io-graphics -dvid=0x126f,did=0x0501,deviceindex=2 -n /dev/photon2
  307240 io-graphics -dvid=0x126f,did=0x0501,deviceindex=3 -n /dev/photon3
The 4 graphics boards have no VGA-BIOS.
There is no graphics driver loaded for the onboard Interface!
The on board interface is only used by "devc-con-hid ".
It seems to me, io-graphics/devg-smi5xx.so  is errornously attaching my on board graphics by bios calls...
Regards
Michael
Attachment: Text display.conf 1.59 KB
Re: io-graphics disables output from devc-con-hid (solved)
Hi all,
seems to be a bug in many graphics drivers, used for x86.
The call  "disp_register_adapter()" uncondionally switches the device "/dev/con1" to invisible.
I have patched the used driver devg-smi5xx.so, to solve the problem.
-Michael
