Forum Topic - How to swap images using a label:
I'm new to QNX and PhAB, but have been programming for 20+ years. I guess I'm most familiar with the Visual Studio
paradigm.
I am using Neil Carter's example of showing an image using a label.
int ShowImage( PtWidget_t *widget, ApInfo_t *apinfo, PtCallbackInfo_t *cbinfo )
   PhImage_t   *myImg;
   char        myImgFlnm[20] = "PICTURE.BMP";
   /* eliminate 'unreferenced' warnings */
   widget = widget, apinfo = apinfo, cbinfo = cbinfo;
   if ((myImg = PxLoadImage( myImgFlnm, NULL)) == NULL) {
      fprintf( stderr, "Error loading image file %s\n", myImgFlnm);
      PtExit( EXIT_FAILURE );
   PtSetResource(ABW_lblMyImg, Pt_ARG_LABEL_IMAGE, myImg, 0);
   return( Pt_CONTINUE );
How can I swap out the current image with another image after a short delay?
I tried the following, but it simple shows the 2nd image:
   PhImage_t   *myImg, *myImg2;
   char        myImgFlnm2[20] = "PICTURE2.BMP";
   delay(5000); /* delay 5 secs */
   if ((myImg2 = PxLoadImage( myImgFlnm2, NULL)) == NULL) {
      fprintf( stderr, "Error loading image file %s\n", myImgFlnm2);
   PtSetResource(ABW_lblMyImg, Pt_ARG_LABEL_IMAGE, myImg2, 0);
Frank
RE: How to swap images using a label
Setup a PtTimer that checks a "image index" ... after the callback for the PtTimer fires, check the "image index" for
what image to display, and set the Pt_ARG_LABEL_IMAGE with that image, then change the "image index".  The next time the
 PtTimer fires, your "image index" will be different, so you would set the other image to the label.
Preload the image (PxLoadImage) in an application startup callback, you do not want to keep reloading the images -> slow
, and if you do not release, leads to memory leak.
From: Frank Applin [mailto:community-noreply@qnx.com]
Sent: July-26-12 11:51 AM
To: photon-graphics
Subject: How to swap images using a label
paradigm.
int ShowImage( PtWidget_t *widget, ApInfo_t *apinfo, PtCallbackInfo_t *cbinfo ) {
   PhImage_t   *myImg;
Frank
Photon microGUI
http://community.qnx.com/sf/go/post94434
To cancel your subscription to this discussion, please e-mail photon-graphics-unsubscribe@community.qnx.com
Re: RE: How to swap images using a label
Would I be able to change the timer to something that is not a set time?
What I am after is to be able to read a simple text file that has bitmap names and timings (usually in ms). This kind of
 stuff is done in psychology experiments with EEG. You show an image for a period of time and delay. Move to the next
picture with a new period of time (just slightly staggered) and delay. And it keeps doing this process all the way
through the file.
So, the text file might look like:
beagle.bmp, 2000
blank.bmp, 2000
canary.bmp, 2015
blank.bmp, 2000
beagle.bmp, 2045
blank.bmp, 2000
canary.bmp, 2065
blank.bmp, 2000
beagle.bmp, 2100
blank.bmp, 2000
RE: RE: How to swap images using a label
Ok, the key is that the Photon processing is not immediate in the callback versus what you see on the display, so if you
 set image1 then image2, you will only ever see image2.
You never want to stall out in the middle of a callback.
What you want to do is of a rather synchronous nature, with non-equal delay time.
With a Photon app the PtMainLoop() is already running.
There are more hacker ways of going about this, but could you try setting the PtTimer to a really fine repeat, then
check your delays in there?
If not, I will have to think about this for a bit.
Sent: July-26-12 1:39 PM
To: photon-graphics
Subject: Re: RE: How to swap images using a label
through the file.
beagle.bmp, 2000
blank.bmp, 2000
canary.bmp, 2015
blank.bmp, 2000
beagle.bmp, 2045
blank.bmp, 2000
canary.bmp, 2065
blank.bmp, 2000
beagle.bmp, 2100
blank.bmp, 2000
Photon microGUI
http://community.qnx.com/sf/go/post94436
AW: RE: RE: How to swap images using a label
I think Derek's suggestion is just right. Set the PtTimer interval to 1ms or so; checking a delay count doesn't generate
 so much overhead.
Try to pre-load the images and delay counts when starting your application (or when opening the definition file).
- Thomas
----- Originalnachricht -----
Von: Derek Leach [mailto:community-noreply@qnx.com]
Gesendet: Thursday, July 26, 2012 01:30 PM
An: photon-graphics <photon-graphics@community.qnx.com>
Betreff: RE: RE: How to swap images using a label
To: photon-graphics
through the file.
beagle.bmp, 2000
blank.bmp, 2000
canary.bmp, 2015
blank.bmp, 2000
beagle.bmp, 2045
blank.bmp, 2000
canary.bmp, 2065
blank.bmp, 2000
beagle.bmp, 2100
blank.bmp, 2000
Photon microGUI
Photon microGUI
http://community.qnx.com/sf/go/post94437
Re: AW: RE: RE: How to swap images using a label
Thanks, guys. I am really new to this (just installed Neutrino, yesterday) and this isn't your normal C/C++/C#/Java
event handling coding. So, let me look at the PtTimer and try to absorb what you are talking about.
Should I even be attempting this via PhAB?
Frank
AW: Re: AW: RE: RE: How to swap images using a label
I'd suggest PhAb. It sets up the code framework for you, lets you drag-and-drop the widgets you want, and also generates
 code templates for the callbacks you specify. Much easier than doing everything in code yourself.
- Thomas
Von: Frank Applin [mailto:community-noreply@qnx.com]
Gesendet: Thursday, July 26, 2012 02:00 PM
Betreff: Re: AW: RE: RE: How to swap images using a label
Frank
Photon microGUI
http://community.qnx.com/sf/go/post94439
I will say this for Microsoft, though. Their documentation is chalked full of examples, which make learning a new tool
set and APIs much, much easier.
RE: AW: RE: RE: How to swap images using a label
You have read the Photon Programmers Guide?  Yes, there could be more docs.
Sent: July-26-12 2:24 PM
To: photon-graphics
Subject: Re: AW: RE: RE: How to swap images using a label
Photon microGUI
http://community.qnx.com/sf/go/post94442
There's an example of this in the Photon Programmer's Guide. See "Animation" in this file:
    http://www.qnx.com/developers/docs/6.5.0/index.jsp?topic=/com.qnx.doc.photon_prog_guide/draw.html
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
Sent: Thursday, July 26, 2012 2:24 PM
To: photon-graphics
Photon microGUI
Re: RE: AW: RE: RE: How to swap images using a label
Thanks, Steve!! That is very useful!
Frank
Steve do you have a suggestion for the staggered delays I'll need for how long the image is displayed? A couple of the
guys on here have suggested PtTimer, but the documentation said it's not very accurate (use RtTimer instead). Why
couldn't i use uSleep() or delay() kind of function to hold the image on the screen for a specified period of time?
Thanks again for the help.
RE: RE: AW: RE: RE: How to swap images using a label
I'm a bit rusty on Photon, as it's been a while since I worked on those docs. If you call delay() or something like that
 in a callback, you're delaying the processing of events by PtMainLoop(), which isn't a good idea, as your entire
program--including the processing of mouse buttons, the refreshing of windows, and so on--is delayed. PtTimer and the
RtTimer* functions work correctly with the event loop. As I recall, the inaccuracy can happen because the expiry of the
timer joins any other events that are already in the event queue.
If you're doing a simple animation where the delays are in seconds, PtTimer is probably good enough. If you need hard
realtime, especially with very short delays, you need to use a timer in a separate process that doesn't use the Photon
event loop.
You can change the delay by resetting Pt_ARG_TIMER_INITIAL to the next delay, in the timer's Pt_CB_TIMER_ACTIVATE
callback.
Some of the people who are monitoring this forum know this stuff a lot better than I do, so I hope they'll correct me if
 I got something wrong.
Technical Editor
Sent: Thursday, July 26, 2012 2:49 PM
To: photon-graphics
Subject: Re: RE: AW: RE: RE: How to swap images using a label
Photon microGUI
http://community.qnx.com/sf/go/post94448
Re: RE: RE: AW: RE: RE: How to swap images using a label
I guess this comes down to a design question then.
Should I be displaying the images (I'm assuming using RtTimer because I need accuracy) in a separate thread, in
background process, in work procedure, or in some other method that I haven't read up on, yet?
A user will basically be clicking on a Start Button of a simple dialog to open this new dialog that displays the images
for the staggered amount of times (read in from the file and stored in some global structure at the start of the
application).
Thanks.
RE: RE: RE: AW: RE: RE: How to swap images using a label
How "accurate" do you need?  I understand your requirement for the delays, but how close to these delay values is
necessary?
PtTimer in most cases is feasible.
I would get it all running with a PtTimer, with a fine repeat, then check in the callback against your delay values, and
 decide whether to swap the image or not.
It will not be a waste of time, as you could reuse a lot of the code with the RtTimer, if it is really necessary.
Sent: July-27-12 10:03 PM
To: photon-graphics
Subject: Re: RE: RE: AW: RE: RE: How to swap images using a label
application).
Thanks.
Photon microGUI
http://community.qnx.com/sf/go/post94457
Re: RE: RE: RE: AW: RE: RE: How to swap images using a label
Hi Derek,
First, thank you for taking your time to be so helpful. These are going to need to be accurate to within a few
milliseconds. The caveat that I don't know if I mentioned in a previous post or not is that before and after the image
is displayed I will be sending a short pulse to a parallel port line connected to a PC running EEG software. So, if an
image is displayed for 2025 milliseconds - we want to be able to look at the EEG between the parallel port pulses
(called events in the EEG world) and hopefully it's damn close to 2025 milliseconds. Does that answer your question?
Frank
RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Yes it does.  Are you using QNX650?
Sent: July-27-12 10:49 PM
To: photon-graphics
Subject: Re: RE: RE: RE: AW: RE: RE: How to swap images using a label
Hi Derek,
Frank
Photon microGUI
http://community.qnx.com/sf/go/post94460
Re: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Yes I am.
RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Since you are looking for 'synchronous' updates of the images, have you considered going straight to the metal and use
GF instead?
Or are you hoping to have all the buttons and such in the same application as the image display?
Sent: July-27-12 10:59 PM
To: photon-graphics
Subject: Re: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Yes I am.
Photon microGUI
http://community.qnx.com/sf/go/post94463
Re: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Forgive my ignorance, but what is GF? I would like to keep it all in one application if I can.
RE: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
It is the Advance Graphics Framework APIs.  It is low level draw API calls, and is more synchronous in nature (no main
loop).
OK, if you want it all in one app, then get it up and running with PtTimer, then recode to RtTimer.
The only reason I am suggesting to use the PtTimer first, is because it is easier, and you can work out all the logic
first.
Sent: July-27-12 11:12 PM
To: photon-graphics
Subject: Re: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Photon microGUI
http://community.qnx.com/sf/go/post94465
Re: RE: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
OK. I'll head down that path, first. Thanks again for your patience and help.
Frank
Hi Derek,
I hate to ask such basic questions, but the documentation is seriously lacking in example code.
I created a base dialog with a PtTimer and a button on it.
PtTimerImage has an initial value of 0 and a repeat value of 1. The Activate callback is called DisplayImage (just using
 printf(), now).
PtButtonStart has an Activate callback named StartTimer.
What I am trying to accomplish in this little test program is that when I click the Start button, the timer's initial
value is set to 5000 which should then call the DisplayImage callback (if I'm understanding this correctly). In the
DisplayImage callback - I want to display the time of day and re-set the initial value of the timer to 1000.
So, the code for the StartTimer callback looks like:
PtSetResource(ABW_PtTimerImage, Pt_CB_TIMER_ACTIVATE, Pt_TIMER_INITIAL, 5000);
The code for the DisplayImage callback looks like:
printf("here\n");
time_of_day = time(NULL);
printf("It is now: %s\n", ctime(&time_of_day));
PtSetResource(ABW_PtTimerImage, Pt_CB_TIMER_ACTIVATE, Pt_TIMER_INITIAL, 1000);
It builds fine and when I run it from a terminal console - the dialog appears, I click Start, and I get a memory fault.
Can you help starighten me out, please?
Frank
RE: RE: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
You want:
PtSetResource(ABW_PtTimerImage, Pt_ARG_TIMER_INITIAL, 5000, 0);
And if you want a repeat:
PtSetResource(ABW_PtTimerImage, Pt_ARG_TIMER_REPEAT, 5000, 0);
In the lines below you are setting the callback resource to reference the PtCallback_t pointer (void *)Pt_TIMER_INITIAL,
 which is just a number constant, which causes the crash.
Sent: July-27-12 11:48 AM
To: photon-graphics
Subject: Re: RE: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Hi Derek,
 printf(), now).
printf("here\n");
Frank
Photon microGUI
http://community.qnx.com/sf/go/post94473
Re: RE: RE: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Thanks, again, Derek. That works.
I'll work on the image part next.
Have a great weekend!
Frank
Hey Derek,
I know it's been a while, but I did get my first experiment protocol running using the PtTimer. It's accurate to about 2
 ms, which isn't bad at all.
I was wondering, though, if, now, you could please show me just a simple example of using RtTimer (RtTimerCreate and
RtTimerSetTimer).
Frank
When I get a moment, I will try and locate some code.
Regards.
Sent: August-06-12 10:40 AM
To: photon-graphics
Hey Derek,
RtTimerSetTimer).
Frank
Photon microGUI
http://community.qnx.com/sf/go/post94657
Hi Derek,
I have gotten some code from Dennis at QNX. Just trying to work out why the interval expiration time doesn't seem to be
working.
Frank
The price of greatness is responsibility.  - Winston Churchill
----- Original Message -----
To: "'photon-graphics@community.qnx.com'" <photon-graphics@community.qnx.com>
Cc:
Sent: Wednesday, August 8, 2012 9:23 AM
Subject: RE: RE: RE: RE: RE: RE: RE: AW: RE: RE: How to swap images using a label
Regards.
To: photon-graphics
Hey Derek,
RtTimerSetTimer).
Frank
Photon microGUI
Photon microGUI
http://community.qnx.com/sf/go/post94688
Ok, thx.
Sent: August-08-12 9:37 AM
To: photon-graphics@community.qnx.com
Hi Derek,
working.
Frank
Cc:
Regards.
To: photon-graphics
Hey Derek,
RtTimerSetTimer).
Frank
Photon microGUI
Photon microGUI
Photon microGUI
http://community.qnx.com/sf/go/post94689
