Forum Topic - multimonitor configuration:
I'am having a large problem trying to configure QNX 6.5 or 6.4.1 with 2-3 video cards. Photon starts, but after some
time, when user moves windows (pterm for example) between screens computer hangs (sometime 3rd monitor crashes). Cards
are Ati Radeon 9250(PCI) but I tried also Radeon 7000 (PCI). Resolution has to be at least 1680x1050@60Hz
Re: multimonitor configuration
This is a very difficult topic. The major reason is the H/W. When we tested the multi-display mode we identified that
two Radeon cards would not usually work together. The symptoms are just like you described -- driver's crashing, system
lock-ups. But we came across some Radeon configurations that would work. I do not have the model numbers, but I think
those were an AGP and a PCI radeon.
In general it is very difficult to find a working combination. We have came across of a few. For example a Radeon and a
Carmine (which doesn't have a VGA BIOS) will work together pretty well -- but again, not always. For example some x86
systems would not even boot when the cards are plugged-in.
You may have a better luck if you get a specialized graphics adapters (of the same kind I assume) that can work
alongside in one system. Most likely you will need a custom driver too.
