Forum Topic - Photon Fullscreen App:
I am new to Photon and i am trying to figure out how to make a simple fullscreen application with Photon. I only need a
simple GUI with buttons and labels. The Display will be a touch-screen.
Can somebody help me please?
Best Regards
Stephen
RE: Photon Fullscreen App
You mean without the window dressings?
Sent: October 4, 2010 11:13 AM
To: photon-graphics
Subject: Photon Fullscreen App
fullscreen application with Photon. I only need a simple GUI with
Best Regards
Stephen
Photon microGUI
http://community.qnx.com/sf/go/post69434
Re: RE: Photon Fullscreen App
yes, without the window dressings and other windowing requirements.
Perhaps the QNX Graphic Framework is better suited for my requirement. But GF does not have direct font support as well
as no widget support.
RE: RE: Photon Fullscreen App
In the PtWindow, there are the "Render Flag",
Pt_ARG_WINDOW_RENDER_FLAGS, you can turn off the dressings in there.
Sent: October 4, 2010 12:17 PM
To: photon-graphics
Subject: Re: RE: Photon Fullscreen App
But GF does not have direct font support as well as no widget support.
Photon microGUI
http://community.qnx.com/sf/go/post69449
Re: RE: RE: Photon Fullscreen App
I have done this already. But the shelf is still visible. So it is not a fullscreen application. It only fills the
desktop area, but not the full screen.
I am looking for an approach like it is done in the game "PH Columns". There it is possible to play the game in
fullscreen. This kind of fullscreen look I would like to have too. Is it possible to get this fullscreen look and use
the widgets like buttons and labels too?
An other example. But on a Windows system. There you can set a window to fullscreen. For example the Internet Explorer
or Mozilla Firefox by pressing F11.
ah, I have just seen that the Photon browser Bon Echo supports this fullscreen feature too. How is this done? :-)
RE: RE: RE: Photon Fullscreen App
Columns switches the application into "bypass mode" using
PdDirectStrart() and PdDirectStop().
I would suspect there is a way to do it without using direct mode, I
have cc'ed Misha in case he recalls off-hand.
Sent: October 5, 2010 4:31 AM
To: photon-graphics
Subject: Re: RE: RE: Photon Fullscreen App
fullscreen application. It only fills the desktop area, but not the full
screen.
There it is possible to play the game in fullscreen. This kind of
fullscreen look and use the widgets like buttons and labels too?
Photon microGUI
http://community.qnx.com/sf/go/post69533
Re: RE: RE: RE: Photon Fullscreen App
I am not sure what exactly your goal is, but if you would like to have a window without a frame that covers the entire
graphics region, you need to follow Derek's suggestion and disable all decorations via Pt_ARG_WINDOW_RENDER_FLAGS, the
second step is to set the proper window dimensions via Pt_ARG_DIM/Pt_ARG_AREA. Use the PhWindowQueryVisible() with the
Ph_QUERY_GRAPHICS flag to learn the size of the graphics region.
ich hier? wo? :)
If you don't need window frames etc., and only have *one* fullscreen application, maybe you can just do away with "pwm",
 i.e. not start it at all?
- Malte
Our goal is a fullscreen UI in an embedded environment. We don't have any windowing requirements. We just have to draw
text and buttons (images). The display will be a touch screen.
The result should look something like this: http://nddsoft.com/img/Tracker1.jpg ( it's just an example from google search ;-) )
Perhaps GF is the better solution for our intent. But I think it is very complicated to write strings and multiline text
 with Bitstream Font Fusion. So i am searching for an alternative.
I believe Photon would be a better choice. Do not run shelf and pwm.
RE: RE: RE: RE: Photon Fullscreen App
Yes, follow Misha's previous suggestions, as well as no shelf and pwm
like he mentions below.
Sent: October 5, 2010 10:38 AM
To: photon-graphics
Subject: Re: RE: RE: RE: Photon Fullscreen App
any windowing requirements. We just have to draw text and buttons
search ;-) )
complicated to write strings and multiline text with Bitstream Font
Photon microGUI
http://community.qnx.com/sf/go/post69591
Re: RE: RE: RE: RE: Photon Fullscreen App
How do i disable pwm? I know how do disbale shelf (environment variable PHSHELF_DISABLE). Is there an environment
variable for pwm too? Or do I have to edit the ph script.
Thanks for you very good help!!
RE: RE: RE: RE: RE: Photon Fullscreen App
Are you using the ph script to start everything?  Usually you would just
not start "whatever" on the target.  There does not appear to be a envar
to disable pwm, so you will need to comment out the section in
/usr/bin/ph.  Just make a backup of the script before you do so.
Sent: October 6, 2010 10:42 AM
To: photon-graphics
Subject: Re: RE: RE: RE: RE: Photon Fullscreen App
PHSHELF_DISABLE). Is there an environment variable for pwm too? Or do I
Photon microGUI
http://community.qnx.com/sf/go/post69759
Re: Photon Fullscreen App
  ich hier wrote:
a simple GUI with buttons and labels. The Display will be a touch-screen.
   ... use SDL
(http://community.qnx.com/sf/projects/qnx_community_sdl_project) ...
it's Photon based.
--Armin
> Best Regards
> Stephen
> Photon microGUI
